Question about Kenmore 41389 Electric Double Oven
GE P7 Double Oven, upper ovens heating element not working, seems to have shorted out to the oven bottom about seven inches from the rearmost connection
    President:
  • Kenmore Master
  • 1,922 Answers
You have what is called a "Hot-Spot" in the element and it burned thru,now you need to replace the element
Posted on Nov 19, 2009
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
In the upper oven, the lower heating element started sparking when turned on, and now it looks like it has a 'bubbled' area (about inch long) on it and it looks bent on one area. I guess I need to...
Hi, Yes, that element is toast...
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 20, 2010 | GE JKP27 Electric Double Oven
I have a ge jkp86 electric oven the oven will not heat up .the microwave works and all displays work
First thing that comes to mind is to make sure you are getting the correct voltage to the oven, you need 220 / 240 volts, check your breakers, fuses ,etc.
It is possable for the microwave oven to operate even if the power supplied to the oven is only 110 volts, but that low of voltage is not enough to power up the ovens heating elements.
If all seems well there, then maybe the oven element has failed / shorted ?
Good luck !
Jan 27, 2010 | GE JKP86 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE P7 Wall oven had bad thermostat????
IF YOUR HEATING ELEMENT IS GETTING ORANGE HOT, AND CYCLING, I WOULD SUSPECT THE THERMOSTAT TO BE THE SOURCE OF THE PROBLEM. YOU MAY FIND IT HARD TO FIND ONE THOUGH DUE TO ITS AGE.
Jan 28, 2009 | GE JKP50SH Electric Double Oven
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
GE electric double oven
Colin, the TCO is located on the back of the oven. It will open L2 to the heating element in the event it is open. If this TC0 opens it will not show any error codes. This is for the 27 inch wall oven models only. Catriver...post back.
Nov 09, 2006 | GE JTP48 Electric Double Oven
Kenmore 41389 Electric Double Oven Logo
895 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
