Rookie needs help with utorrent
System tells me my firewall/router is limiting traffic open a port
how do i do this
  • coffeemonter Jan 10, 2008
    i dont think i am using one
    i have a huawei e220 dongle modem from t-moble
Go here: http://www.portforward.com/english/applications/port_forwarding/Utor/Utorindex.htm
find your router. I have wpn824v1 but was only able to portforward for one machine. when i added others, ports would not show up on list. I have latest firmware. hope it works for you.
Posted on Feb 22, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 20 Answers
What sort of router do you have? The procedure for opening a port is different for different routers.
Posted on Jan 10, 2008
Need find out how portforward can you tell me how udp and tcp ports open
Here is the solution to help you out to do the port forwarding as you wished sir..
2wire-gateway-1921681254-300x234.png Once you have accessed your default gateway screen for your router, you will then want to click on the firewall tab at the top of the screen. After the firewall summary screen opens, you will then click on the firewall settings tabs to begin setting up an open port on your 2wire dsl router.
2wire-firewall-300x234.png Once the firewall setting screen opens you can then add an open port to your specific pc. Under step 2 you will see a list of predefined applications that have already been created for certain video games, servers and telephony (VoIP) services. Since in my example we are opening a port for Utorrent, we are going to manually configure port forwarding for one of my pc's. To be opening a port for Utorrent, click on "add new user-defined application" you can find the link just below the list on the left side of the screen.
2wire-edit-firewall-settings-300x234.png Once you click on add new user-defined application, you should have a window that resembles the one below. Within this window you should now be able to enter a name for the application that you are opening a port for. Underneath the application name, you know have the choice of either tcp or udp, and then you would enter a port number or a port range that you want to open up.
2wire-add-user-definition-300x234.png For security reasons, you should only open one port, unless the application specifies otherwise. The more ports that you have open on you router, the more doorways you open for hackers and viruses to enter your home network. Since we are opening a port for Utorrent, you are going to want to click on the tcp box and then enter the port number that Utorrent gives you, in my example I am opening up port number 51225. After you have entered you port number, click the add definition button. Once you have added the definition, you are going to then click on the back button.
2wire-utorrent-open-tcp-port-300x234.png After you have clicked the back button, you should now be at the edit firewall settings screen. All you have to do now is select your computer from the list that is listed After you have selected the computer that Utorrent will be hosted on, all you have to do is find the recently created user defined definition from the list under number 2. After you have located the Utorrent port forwarding application simply click on the add button, which should assign the Utorrent port forwarding application to your computer. After you have completed the above steps, you should be all set; now your Utorrent program should download and upload at a faster speed.
I have used Uttorent as an Example for you to have an idea how to do the work.. if you still have any problems or question just send a message i will get to you as soon as possible..
If you like the answer and it helped you please like the answer, it will be a great help.. Thanks
Jun 01, 2011 | 2wire (2701HG-B) Wireless Router
Firewall/ Router Limiting Network Traffic.you need to open up a port so other can connect to you what it mean, how to over come tis problem
You need to write a rule on your firewall so that the traffic can be permitted. If you need help in writing the rule let me know the following details.
1. When you are getting this message (e.g yahoo messenger, MSN messenger, Internet access)
2. What is the firewall you have
3. do you know the administrator username and password
Nov 24, 2009 | Computers & Internet
Problem opening port for utorrent with DGL 4300 router
You must set static IP on your computer where the utorrent is installed. Make sure no firewalls are enabled on your computer like windows firewall or any other firewall like norton, mcaffe, zone alarm and the likes. You should forward the port on separate protocol. Go to portforward.com for more information on how to forward port for utorrent
Jun 14, 2009 | D-Link GamerLounge DGL-4300 Router...
How to configure ports on my modem
U will have to learn port forwarding.............u didn't mention router ur using since differnt router have different settings.......goto http://192.168.1.1 and search for port forwarding settings. Me too had this prob before port forwarding speed 15~20Kbps download and after 197~208Kbps.
Good luck with port forwarding.
Jan 18, 2009 | Computers & Internet
Network connection?
Log into your router. You should have a manual on accessing it. Find a selection called port forwarding. What your going to do it set port 6881 to be forwarded to your computer to get your IP address by going into /Start/Run/ type cmd.
Once the prompt is open type ipconfig /all and retrieve your IP address. once that port is forwarded to your computer you should be good to go.
Jan 15, 2009 | Zyxel P660HW-D1 Router
Problem with jetspeed 520 and utorrent.
Please add the utorrent service on the policy which permits traffic from your LAN to internet.
Nov 10, 2008 | SonicWALL (01-SSC-2488) Firewall
A firewall router is limiting my network traffic
A Firewall/Router is Limiting my network Traffic. I need to open up a port so others can connect to me.
Oct 23, 2008 | Computers & Internet
Router problem
Hello!
Here is a guide on how to setting up port forward on DSL 500T for uTorrent:
http://www.portforward.com/english/routers/port_forwarding/Dlink/DSL-500T/Utorrent.htm
If you can't reach the router as described in the link above, than you need to contact whoever provided you with this router. If the router was provided by your ISP (internet service provider) than contact them directly asking how to access your router.
Hope this helps!
Sep 23, 2008 | Computers & Internet
Firewall/ports
Hello there, you only need to open a port for utorrent, if you use a Router device for sharing your internet connection to more than 1 computer. If you do indeed own a router then you will need to log-in to it, via your web browser and change the necessary settings to forward the port that utorrent uses, to your local computers address.
Please write again if you need more support.
Hope this helps.
Apr 06, 2008 | Symantec (10427438) Firewall
TEW-452BRP - can't open a port (forward)
I had the same problem.. the router did forward another port for me (port 12345) so i just set the port for uTorrent to 12344 and it magically worked... i'm not sure why but i would try setting the port to a lower range
Feb 23, 2008 | Trendware TEW-452BRP Wireless Router...
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
