Question about Mitsubishi WS-55859 55" Rear Projection Television
My mitsubishi TV ws-55859 does not turn on. The green timer light comes on and goes off after 3-4 seconds but tv does not turn on. What could be the problem? Help please......
  • Mitsubishi Master
  • 5,138 Answers
Poor solder connection and Bad STK ICs 2 of them replace Both Big Black IC will have part number on them Call Mats for STK 1-800-628-1118 example
STK392-570.
Posted on Nov 18, 2009
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: mitsubishi model ws-55859 tv is red and red
If it is WS-55859 and you go into the customer menu and find red or blue are skewed and will not adjust---you have a convergence problem.
This model uses a single STK-393-110 convergence chip--it and any of the protect resistors around it that are bad will need to be replaced and the set adjusted.
The chip can be purchased on Ebay for about 12 dollars plus shipping--total parts cost should be under 30 dollars!
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
They tell you everything you will need and how to do the repair---If you or someone you know can do it I can post or get the instructions to you.
If you cannot do it shop around your area--most shops are going to get 300 or MORE for this kind of repair and many will not do in in your home--Any good tech can do it in your home in about 1 hour--I know as I have done hundreds of them.
If you have questions or need help let me know--I am here to help people.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 11, 2009
Push power button and timer button lights for a few seconds and then tv turns off model is Ws 55859
When it shuts down go to the set and press the menu and the Device/Input button both in together and hold for 6 seconds then count the two digit blink code from the power indicator. it will blink a two digit code which repeats several times.
Jul 23, 2011 | Mitsubishi WS-55859 55" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Tv does not stay on
If you have a rear projection, it is the bulb. Ypou need to replace it.
Jul 24, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code...  I have the same problem and I get a 1,2 code....   I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is smartin38@verizon.net
Sep 11, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Green timer light turn on tv turns off
Read the info from this link to see if that applies to your TV.
Jul 23, 2008 | Mitsubishi WS-55859 55" Rear Projection...
WS-55859 Won't Turn On
this is a job for experienced tech most of the problems are rela ted to convergence IC's in this case
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859
Check any/all fuse devices in power supply.Let me know.....T.
By the way,the tv serial # is 107543. I assume the model # is
as stated==WS-55859.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
348 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
