I have a Mitsubishi 737series. The TV recently had to have a new light engine. After the engine was replaced the TV will stay on about 15 minutes and kick off. A flashing red light appears on the TV. The only way to get the TV back on is to unplug the TV and then wait a minute and plug it back in. What is causing this? Please help if possible. Thanks. Jane
    Sergeant:
  • 295 Answers
Sorry to tell you this but I believe you will need to replace the lamp.
Blessings,
A/V Media Tech Guy
Posted on Nov 23, 2009
  • 556 Answers
Have you ever had the lamp changed, if not this could be the problem. Look under the red light and see if it says lamp.
Posted on Nov 18, 2009
Replaced bulb but tv comes only comes on for about 10 to 15 seconds then shuts down and red light flashes
It sounds like you have a bad ballast board, or possibly the power supply going to the ballast bulb. I'm afraid that if you do not have the repair experience on solid state TV sets, you will need to contact and authorized Mitsubishi repair center. Good Luck
Jul 09, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitusbishi dlp tv shut off
hi when you replace the lamps, the lamp counter needs to be reset,thanks
shaun
Jun 28, 2017 | Mitsubishi WD-73737 73 in. HD-Ready TV
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Car stuck in idle
Trying disconnecting the battery again this time for 10 to 15 minutes. Then reconnect and see if it clears the problem.
Nov 28, 2008 | 2003 Mitsubishi Diamante
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
IS THIS TV PLAYING OUT
Color separation is called convergence mis-alignment......that
problem can be repaired...............Blurry,darker when cold may
be a bit of difficulty..............Have a skilled tech give it a look.....T.
Nov 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
