Question about Roper MHE11REB Microwave Oven
Handle I have 250 of these microwaves that were installed in our apartments in 1997 and 1998. They all still work and look great. The problem is that the handle is not made anymore, so every time a handle breaks I have to change the whole microwave. Neither the 4359046 (white) or the 4359051 (black) handles exist anywhere. Any suggestions?
  • 45 Answers
Have some handles fabricated locally. They wont look like the original but will surely last longer.
Posted on Jan 10, 2008
Microwave door handle broken
That's correct the door has to come apart. Just be careful that screen is actually a choke to keep in any microwave radiation. Put everything back exactly as you took it apart.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
How do i install a high point microwave door handle?
Look really good on inside of door. You should be able to remove the inner panel and then have access to bolts for the handle? If not... Epoxy is your best friend at this point! Good luck!
Feb 08, 2014 | Microwave Ovens
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Need to replace the handle I have the part but how do i desassemble the door properly
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jun 03, 2009 | Microwave Ovens
Need to replace handle on GE Spacesaver Microwave J VM130K 004.
I looked up the $39.99 part ! (almost as much as a new microwave)
If you want to replace the handle, get the new handle and see how the new handle goes on and you can determine how to take off the old handle.
Mar 26, 2009 | GE Microwave Ovens
Door handle replacement
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
Do not forget to rate the solution.
Thanks.
Feb 12, 2009 | KitchenAid KHMS155L Microwave Oven
Getting door frame apart to install new handle
If you're replacing the handle, then order the choke cover..It's the piece on the inside of the door that covers the handle screws. No matter how carefull you are, it is almost guaranteed to break. If you break it, then you have one, and if not, send it back. DO NOT OPERATE MICRO WITHOUT CHOKE COVER.
Dec 09, 2008 | Kenmore 62702 Microwave Oven
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Microwave Ovens Logo
61 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Mark Cheong
Mark Cheong
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
