Question about Denon AVR-5700 Receiver
The receiver turns on and immediately goes to standby
  • 52 Answers
The unit is going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Posted on Nov 24, 2009
Not switching on!
A short has transpired before the fuse. Now in protect mode. See a tech.
Mar 22, 2014 | Teac AG-980 4 Channels Receiver
Yb125 battery wont charge
Instructions
    • 1 Check the main power cord if the receiver fails to turn on. If it is unplugged or loose, securely plug it in to an electrical outlet. If this fails, try plugging the receiver in to another outlet. If the receiver starts, the previous outlet is damaged. Call an electrician to repair it. If this fails, try turning the receiver on with the remote. If this does not turn the receiver on, try turning it on with the power button on the receiver itself. If this works, change the remote's batteries.
    • 2 Leave the receiver in "Standby" mode if it immediately goes into "Standby" when you turn it on. With the receiver still in "Standby," unplug the main power cord. Wait for around 30 seconds, then plug the receiver back in.
    • 3 Check the audio cables if you experience sound issues. If they are loose or disconnected, securely reconnect them. If you still do not have any audio, press the "Input" left or "Input" right buttons on the front panel to select the appropriate input source. You can also set the receiver to automatically detect input signals and select the appropriate input source. To do this, access "Audio Select" from the main menu and select the "Auto" option.
    • 4 Try factory resetting the receiver if you experience persistent audio or video issues. Press the "Standby/On" button on the receiver's front panel. Press and hold the "Tone Control" button, then press "Standby/On" again. Select the "Preset" option, then choose "Reset." Press "Standby/On."
Jan 14, 2013 | Yamaha Motorcycles
I have a ev205 yamaha violin its covering of the bridge is damaged how can i solve this problem the black covering is sliped off from the wooden bridge plzz help me
Instructions
Jan 13, 2013 | Motorcycles
I have a Sony kv-40xbr800. The standby light flashes 6-7 times and does not turn on. If left off for a couple of day, it may turn on. Is there an easy fix?
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Jun 05, 2010 | Televison & Video
Trips and switches off
Hello Fixya customer,
Thank you for your question.
The best way to fully isolate the fault is to disconnect all the speaker wires, and verify that there are no strands of wire shorting between the speaker terminals on the rear of the unit.
Turn the volume all the way down, full CCW, and if it goes into shut down with the STBY light blinking then there is a fault in one of the amplifier's.
Thank you for using Fixya, and if I can be of further assistance please ask.
May 01, 2010 | Onkyo TX-SR706 Receiver
Powers up ok but when i turn anything on it immediately goes back to standby as soon as there is any signal.
you have a short circuit somewhere in the speaker wiring. or a problem with one of the speakers. try disconnecting all the speaker connections the re-connect one at a time and you will probably fine the problem one.
Feb 19, 2010 | Insignia 200W Stereo Receiver
Rx-dp15b reciever turns on, then immediately goes into standby
Just worked on a Sony with a similiar problem. I replaced the Power Amp Drivers. They were labeled as IC's on the circuit board. They were relatively inexprensive, around $33 total. This fixed required knowledge in using a Soldering Iron and Desoldering Wick. Also I had a schematic of the circuit board which can be purchased on the internet. Hope this works for you. It might be best to just have a tech look at it, if you have no electronics knowledge.
Jan 10, 2009 | JVC RX-DP15 6.1 Channels Receiver
Denon AVR-1508 Standby Issue
The problem is with one of the Channel power transistors. I have the same problem I am searching to find out how to test them to find out wich one is bad.
May 14, 2008 | Audio Players & Recorders
Power works but receiver will not stay on
The outputs are blown and will require repair.
Dec 17, 2007 | Onkyo TX-DS575 Receiver
Denon AVR-5700 Receiver Logo
476 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
