Question about Vacuums
I have an Easy-Flo central vac unit. The handle on the electric hose has a switch on the handle. With the switch on ''O'' in the center, it's off. On the left, is the ''I'' position. The vacuum runs but the power brush doesn't. On the right is the ''II'' position. The switch won't flip that way. It feels stuck. It feels as if there is something underneath of it that won't let it push that direction. I have the switch out of the handle, but I can't seem to get the actual black casing around the switch itself apart. Anyone that can help?
  • 64 Answers
Switches are not usually designed to be dissembled.
I would strongly suggest that you dont take the switch apart. you are better off getting a new one. then if you feel like it you can take the old switch apart and if it dosnt work you still have a new switch. if you decide to dissemble the old switch be vary careful there are very small parts in there that will fall out. and most of the time the casing will crack when you pry it apart.
Good luck
STITCHES
Posted on Nov 18, 2009
  • 701 Answers
You can't get that apart. I repair the switches on these hoses a lot. The only way to fix it is to just get a new switch and replace it. You can get a replacement switch here:
Switch Replacement
I am buying a central vac system, can you tell me the better of the easy flo or nutone brand. I want the one with the least problems. It appears to me that the easy flo has fewer problems, thank you
between the two brands... stay away from the nutone. If you can get it, the Beam, Eureka, or even the Electrolux and Kenmore(sears) would still be better. The warranty would be better on the Beam and Eureka (7 or 10 and one model is even 15 years)
Good luck on your purchase.
Mark
Nov 09, 2010 | Easy Flo EF1525 Central System Vacuum
I have an easy flo vacuum model # 199C and it won't shut off. It started out as an intermitent problem but now will not shut off when the hose is unplugged, nor when the off/on switch on the main unit is...
Remove the low voltage wires (top left) if the vac unit still runs the problem is with vacuum
if the Vac stops running then there is problem with the low voltage wires in the home possible short some where in the system Chech the inlet doors first. Easy Flo vacuums have a lifetime warranty call 1800 easy Flo.
Feb 13, 2010 | Easy Flo EF1500 Vacuum
Beater attachment has no suction.
Your hose issue is isolated from the garage. You have a switch problem in the handle of the hose.
If the hose has a swivel handle your problem will lie in the switch itself or the contact rings within the lower portion of the handle itself. If this is a light gray hose with swivel handle several years old switches were an issue from time to time . The problem can normally be fixed by replacing the internal wiring harness in the hose.
Oct 03, 2009 | Easy Flo EF1600 Central System Vacuum
Easy Flo Central vacuum will still work at about
Yes you can easily test for a clog, and a crack for that matter.
to test for a clog push a dry garden hose through the entire system until it comes out at the other end.
to test for a crack, Disconnect the pipe that comes from the house to the central vac unit. Turn on the unit and put your hand over the opening directly at the central vac unit.(Using the utility inlet at the unit will not accomplish the same thing.)
  • Step 2 If your suction is good, then reconnect the tubing and turn on the switch at the unit. If there is no switch, plug your central vacuum hose into one of your inlets to start the system. Then have someone completely seal the hose with their hand. While the unit is running go to the exhaust. With everything closed you should feel almost nothing coming from the exhaust. If you feel very little exhaust, then you do not have a leak
  • Jun 06, 2009 | Easy Flo EF2300 Central System Vacuum
    Central Vac will not turn on.
    These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
    Best of Luck
    Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
    Easy-Flo 1525 will not turn off
    There is a relay back on the master unit. When the hose is plugged into the inlet the metal on the coupling completes the electrical circuit to the relay. In your case the coupling has a split and the circuit continues to the switch in the handle. As long as there isn't any conductive surface left across any of the contacts in any of the inlets, the relay is hung up. I never heard of that happening until today when I responded to the exact same problem on a different machine. The relay needs to be replaced.
    The "screeching" on the other hand should have nothing to do with the relay. That sounds like a motor bearing without proper lubication and/or going bad.
    May 22, 2009 | Easy Flo EF1400 Central System Vacuum
    NuTone CV353 Central Vac does not start when hose is plugged into
    Try to plug the hose in sideways. So the top of the hose is rotated 90 degrees. If the unit turns on then there is something wrong with the hose. It might be a short or it could be a bad switch on the handle. If the unit still wont turn on I would think that maybe the low voltage wire got disconnected from the unit or there is a break in the low voltage wire somewhere along the way. Let me know if you plugging the hose in sideways works.
    Feb 22, 2009 | Broan-NuTone CV353 Central Vacuum
    I have a 3 year old NuTone CV 353W central vac system and recently the switch on the hose handle does not turn the system on from any outlet in the house. I have to plug the hose into the outlet and then...
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=567634
    Generic problem for all Vacuums
    I have a 3 year
    posted by patfitz on May 03, 2008
    I have a 3 year old NuTone CV 353W central vac system and recently the switch on the hose handle does not turn the system on from any outlet in the house. I have to plug the hose into the outlet and then turn the unit on from the switch on the canister. Any help would be greatly appreciated. Thanks
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that come to mind, 1st. you may have a bad switch in the hose and in most cases that can be repaired – if not you would have to purchase a new vacuum hose. 2nd. You may have a bad inlet valve in your hose and most of them are low volt of which would only cost less than $10.00 and can be replaced yourself unless you have what they call a SuperValve of which has 2 low volt wires and then it is wired to your home electricity and that should be replaced by an licensed electrician. It is a low volt and high volt inlet.
    #3. the last thing you may check id that you may have a bad relay in the canister itself. Because you should be able to turn on the Central Vac with the switch on the hose and everything should work just fine . feel free to contact your local vacuum cleaner dealer in your area of call the Nutone Factory cust serv line for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://nutone.com/ Customer Service
    Nutone Inc.
    9825 Kenwood Road
    Suite #301
    Cincinnati, OH 45242
    Customer Service 1-888-336-3948
    Technical Support 1-888-336-6151
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    May 03, 2008 | Broan-NuTone CV450 Central Bagged Central...
    I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
    I have a one year
    posted by jon89 on May 02, 2008
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://www.beamvac.com/usa/ Owner Support
    Customer Service 1-800-369-2326 Phone #
    Email: beam.dir-support@beamvac.com
    Technical Support: beam.tech-info@beasmvac.com
    Go Ahead. Use Us.
    May 02, 2008 | Vacuums
    Vacuums Logo
    80 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
