Question about Verizon Communications Samsung Alias Cell Phone - Black
My alias keeps turning itself on and off continuously and I can't do anything else with it.. is there an easy solution to this? Is it a problem with the battery or phone itself? And once I got a message on my phone that said this: Download started @ USB_ISR Bootlock Version: u740:ZL05.2
My tv, when plugged in just keeps turning itself on and off in intervals of about 3 seconds. It doesn't give time for anything to come up on the screen at all.
Problem is in standby power supply or microprocessor area---not the do it yourself repair and likely not economical to repair due to age and brand of set.
Sep 01, 2012 | Philips 60PP9352 60" Rear Projection...
My samsung alias 2 won't completely turn on it just keeps on showing the verizon wireless part and it goes dark then lights back up to the verizon wireless screen but when i have it plugged into the...
HI a strong Listen take the battery out of the alias and then look at the battery and see if you have any corrision on the battery or the contacts of the battery, Next take a toothrush and clean the contacts. Also I want you to put the battery back into the phone. See if the phone reboots. If the phone reboots you should be able to use the phone. If the phone doesn't turn after that you need to go to the nearest corporate store and have them replace your phone, Hope this help
Dec 24, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
My Alias 2 keeps shutting down by itself
U'll need to use a software update.contact your local samsung dealer or u can do it by your own if u have the knowledge.All the software is free and u'll need a some knowledge in the process
Aug 04, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
Can I use the Samsung alias 2 is an Internet modem
    Using Alias 2 as Modem
  1. The Alias 2 can, in fact, be used as an external modem to connect your computer to the Internet. To do this, the phone must plug into the computer via USB. The USB data cable specific for the phone is purchased separately and can be found at most any cellular phone store and eBay. Because USB is a powered connection, anytime the phone is plugged into the computer for use as a modem, it will also remain charging, so you don't have to worry about battery life while online.
    In addition to the cable, you must subscribe to a specific service through your cellular provider in order to use the Alias 2 as a modem. This plan will be a "tethering" plan and will have a separate charge each month to use it, similar to a cell phone's data plan. By signing up for this feature, your phone will be able to dial into the data network and utilize the Internet connection as a modem, allowing any connected computer to surf the Internet. Once this feature has been activated on your account the option will become available on the phone itself to enable tethering.
    At this point, you should be able to turn on tethering, connect the phone to your computer via USB cable and select the phone on your computer as an Internet connection source.
    It is important to note, however, that the Alias 2 uses a different and slightly older system on the 3G cellular network. Because of this, using the phone as an external modem will produce a slightly slower Internet connection than a traditional modem or even a newer phone would. However, as a backup solution for Internet connectivity or a travel solution, the Alias 2 will work just fine as a modem for your computer or laptop.
Apr 01, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
HP ProBook 4515s no sound
You will have to drive the sound on your system or you download it from www.hp.com/download then type in the model and the driver you want which is sound driver then when you download it run it on your system and that end the problem anything else?
Mar 06, 2010 | Computers & Internet
Why does my samsung alias keep taking pictures
Something is hitting the camera button on the side. Many phones have this issue and there's no way to fix it.
Feb 14, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
What does the call restriction feature do on a samsung alias phone when turned on ?
it might not do anything except say *restricted* but most likely it will say if someone calls you *incoming call restricted* =)
Sep 03, 2009 | Verizon Communications Samsung Alias Cell...
Cannot format memory card
The Samsung Alias can only use up to 2gb microSD cards. I had this same problem after purchasing a 12 gb card only to discover that I could not use it with this phone. Hopefully this will be fixed when they make the Alias 2.
Apr 13, 2009 | Verizon Communications Samsung Alias Cell...
How can i change my nickname in yahoo room in messneger 9
Yes. You can create up to six (6) additional aliases to use instead of your Yahoo! ID, so you can keep private details private.
Here's how:
  1. Click the Messenger menu in Messenger.
  2. Select My Account Info. This opens a browser window displaying your account details.
  3. Click the Edit/Create Profiles link on the right side of the page.
  4. In the lower portion of the page, click Add an alias.
  5. Enter a new alias in the box that opens.
  6. Click Save.
  7. At the bottom of the page, click Close.
Entering Yahoo! Chat from Yahoo! Messenger is easy. Here's how:
  1. Sign in to Messenger.
  2. Select Messenger from the menu bar.
  3. Select Yahoo! Chat from the drop down menu.
  4. Click Join a Room.
  5. Select your Yahoo! ID or an alias from the drop down labeled Enter Chat Room As.
  6. Select a category on the left and a room on the right.
  7. Double-click the name of the room you want to enter.
Jan 01, 2009 | Yahoo Messenger
Verizon Communications Samsung Alias Cell Phone - Black Logo
189 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
TO Lady
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
