Question about Texas Instruments TI-84 Plus Calculator
I use the Y= key and type in my two equations, then i hit the graph button and it doesn't show up, why won't it graph for me?
  • Texas Instru... Master
  • 7,993 Answers
Once you enter an equation the corresponding equal sign is highlighted by default. Before you draw the 2 graphs, move the cursor to Y3 or Y4 and verify that the = signs for Y1 and Y2 remain highlighted. If one is not highlighted, move the cursor on it and press ENTER.
If you still have problem, press [2nd][STATPLOTS][4: PlotsOff] [ENTER]
Command PlotsOff echoes on main screen. Press [ENTER], screen displays Done.
If all else fails, just reset the RAM by pressing [2nd][MEM][7:Reset][1:All RAM][2:Reset], press [CLEAR] to clear the message.
You shouild make it a habit to clear the RAM every time you start a new type of problem.
Hope it helps.
Posted on Nov 18, 2009
  • k24674 Dec 31, 2009
    If you still can't see anything on the graph, it may be due to your function being out of range. Try playing with the window dimensions, or the Zoom function. Try Zoom Standard first, then ZoomIn.
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
Jun 11, 2014 | Texas Instruments TI-86 Calculator
Graphing doesnt show
Depending on the function you are drawing, it is possible that the graph is out of range of the windows dimensions. Try Zooming out to see a bigger portion of the plane. If you know where the function intercepts one of the axes, you might want to center the graph around that point.
Jan 16, 2012 | Texas Instruments TI-84 Plus Calculator
My fx-9750GA PLUS wont graph lines, cicles or paraballas
Sure it does! Did you ask it to graph?Here are some screen captures to help you find your way.
To draw functions (regular, parametric, polar, sequences) use the application graph: Highloghted on 1st screen capture. The second screen captures shows you the functions y=f(x). enter a legal expression and press F6 Draw. To set TYPE press the key under TYPE.
To draw conics (circles, parabolas, hyperbolas, and ellipses) use the CONiCS applications. (See 3rd screen ). On 4th capture the equation highlight is one for the parabola. y=x^2
Scroll down or up examining the small graphs. They will show you which equation form to choose.
For the circles
Jun 19, 2011 | Casio FX-9750GPlus Calculator
My TI-84 PLUS calculator wont show the graph after i type in an equation. please help!
You need to fix your graph so that it shows the correct y-axis and x-axis.
It works best if you press the zoom button and then scroll to find the ZoomFit option.
Then the graph should show up.
Jun 15, 2011 | Texas Instruments TI-84 Plus Calculator
My ti-84 is only graphing one linear equation in the y equal when i put two equations in it only show one
The following should help you draw several graphs.
When you enter a function you should press [ENTER] to validate. At the same time, the cursor moves to the next line. Verify that the = sign on the equation already entered is still highlighted.
If for some reason the = sign of an equation is no longer highlighted, use arrow keys to move cursor on the = sign and press [ENTER].
If only one = sign remains highlighted and all others are not, then in all probability the application Transfrm has been executed before and is still lingering in RAM. When in RAM, it takes over the graphing capabilities of the native OS. This prevents you from drawing more than one graph.You must unload it from memory.
  1. Press the [APPS] key.
  2. Scroll down to the line that shows Transfrm.
  3. Highlight it and press [ENTER].
  4. In following screen you are invited to Uninstall or continue.
  5. Press the number to the left of Uninstall. Validate if need be.
  6. Return to the Y= editor to type in functions to graph.
Nov 10, 2010 | Texas Instruments TI-84 Plus Calculator
Keeps plotting the same graph no matter what the function
Hi:
press y= and see what equation are selected . If one y equal is highlighted than the calculator will graph only that equation , Move the curser on what function you want and press select button it should be in the f keys if not press the more button until it shows up okay
Oct 11, 2009 | Texas Instruments TI-83 Plus Calculator
Ti 84 plus problem
The calculator only displays from -10 to 10 on the x and y axes, and both of your lines are outside of that range. However, it is easy to change that.
1. Hit the gray "WINDOW" button that is directly under the screen
2. Change "Xmax" to 150
3. Change "Ymax" to 200
Remember to change both of those values back to 10 when you are done with this problem!
Here's how to graph it:
1. Hit the "Y=" button
2. Enter your first equation after Y1, and your second equation after Y2
3. Look over both the equations to make sure you typed them correctly
4. Hit the "GRAPH" button
5. If you don't see the intersection you will need to adjust Xmax and Ymax again
6. Hit Hit "2ND" and the "TRACE" to bring up the "CALC" menu
7. Scroll down to "intersect" and hit enter
8. Hit enter 3 times (You use the first and second curve options when you have more than 2 lines)
9. It should display the coordinates at the bottom
10. I got (76, 142.1) for the intersection
Thanks for asking this question! I used to do this a much harder way, but while I was calculating the answer to your question I hit a wrong button and accidentally found this method!
Jun 30, 2009 | Texas Instruments TI-84 Plus Calculator
Graphing
i had the same problem .... just go to apps and go all the way down transfrm and click it then click the uninstall button !!!
Apr 01, 2009 | Texas Instruments TI-84 Plus Calculator
No Y's in Table
The tables will not say Y specifically, they only say L1, L2, L3, etc. UNLESS you type in an equation in the "Y=" button menu. When you type an equation in on that page, and then hit "2nd" "GRAPH", you will get X and Y values for that equation.
Jan 19, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
149 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
