Question about Cuisinart Kitchen Appliances - Others
Basket is not staying in place during the kneading process and the noise is unbelievable! Help!
  • 433 Answers
Take the bread pan out of the machine. Start a kneading cycle and see if the noise is still there. If yes then motor spindle is bent, the motor is bad or the belts are pulleys need attention. If the noise you heard is not as bad, then it is the seal on the bread pan ( the seal and shaft that the paddle goes on).
Hank
Posted on Nov 19, 2009
  • jstantonm Jun 07, 2017
    See if the paddle shaft in the bottom of the pan is frozen. If it is, free it up manually. Then get it good and dry and oil it with cooking oil. After that, every time you bake, put the oil for the recipe in first and turn the paddle until it moves freely. Once the oil is in the bearing, it will keep the water out and the machine will move properly. I have gotten away with this fix for hundreds of loaves.
Oster noise when kneading
Are you pushing your pan down into the oven so that the little spring clips hold your pan in place nice and snug?
Jan 25, 2014 | Kitchen Appliances - Others
Loud banging during kneading
you are right.for further help check this link.
www.repairclinic.com
Aug 29, 2008 | Breadman TR875 Bread Maker
During kneading process is the kneading supposed be continuous or stop & go ?
mine stops and starts. so unless there is an obvious problem with your finished loaf, then your machine should be ok. k
Dec 16, 2012 | Black & Decker Kitchen Appliances - Others
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
The paddle for my Breadman BK1060BC has been coming off during kneading. Today, I saw some grey residue in the dough. Is the problem with the paddle, pan or both? Thanks.
I just purchased this 2 days ago and started to use it. I noticed the bread pan would wobble and was noisy during the kneading cycle. On the second use the paddle came off during the kneading cycle. Being a service technician all my life, I started to analyze the problem. I was previously surprised how loose the bread pan fitted into the bread maker and suspected there should be something to support the pan and hold it in place. I could not see anything obvious, but after looking carefully I noticed spring clips on the bottom of the bread pan, and also mating spring clips in the bottom of the bread maker. If I pushed the bread pan down fairly hard into the bread maker the bread pan would snap firmly in place. This stopped the wobbling during the kneading cycle and the paddle coming off. I could not find anywhere in the manual where it explained the bread pan must be pushed firmly down into place until it snaps in. The manufacturer should explain this to their customers on their website.
Apr 23, 2011 | Breadman TR2500BC Bread Maker
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
My paddle keeps coming off when the dough is mixing. What's up with that?
Your paddle is probably worn out and has too much play in it. Some play is necessary to get it off for cleaning but it shouldn't be so loose it is coming off during kneading.
Nov 14, 2010 | Breadman TR444 Bread Maker
I have a toastmaster Bread Box bread machine...I am making French bread...the banging noise was so loud I stopped it fearing the machine was broken...is it ? If not should I continue the kneading/baking...
Unless the sound is mechanical like metal on metal etc. what you may be hearing is the sound of the dough ball being knocked around and kneaded. Sometimes that gets pretty loud. While it is kneading go ahead and open the top and see if you think the dough ball is making the noise. If it seems to be coming from somwhere else then you may have a more serious problem. Is this a new noise or it this the first time you have used the machine?
Nov 08, 2010 | Toastmaster 1183N Bread Maker
Kneading blade stays in bread after cooking.
This sometimes happens. I have a Panasonic.
When you place contents in pan with some machines it is important to place contents
in a particular order. I should try to keep contents away from the kneading blade as you place them.
Another thing that might possibly help is to put a litter olive oil around the blade before adding ingredients.
Hope that this helps
Alleillia
Dec 02, 2008 | Breadman Kitchen Appliances - Others
Kitchen Appliances - Others Logo
792 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
