Question about Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC
Nursery On Dogz 5 my dog has been pregnant for 6 days,when sheshould have only been for 3-5 days,and there is no nursery room.What should I do?
  • Anonymous Dec 11, 2008
    i changed the time on ma computer to speed up the process and i put it back then it showed me the nursery i tried takig her out didnt work andi left but she is still pregnant
  • Anonymous Mar 22, 2009
    i speed up mine,and the dog is still pregnant!and i lost the manual!!
  • 4 Answers
Just wait, mine had the same problem. There wont be a nursery until your dog has the puppies. Believe me, mine took nine days!
Posted on Jan 25, 2008
Synonym for nursery
Synonyms for nursery noun child's room
Jan 18, 2017 | The Computers & Internet
Hello I have a Angelcare baby monitor model ac1100 and have had it 1& half years it hasn't put a foot wrong and all of a sudden the tv monitor side of it is not working properly! It stays a blue screen and...
If you can only see two lines appearing on the screen this may indicate that the parent unit is searching for a signal from its partner and cannot locate one. Check that the nursery unit has fresh batteries and is switched on. If all ok with the nursery unit you may need to "re-pair" the two units together as per instructions. Note that the maximum distance between the Parent Unit and the Nursery Unit is approx. 100 metres indoors. In reality the Signal Strength Indicator on the parent unit should show the strength of signal between the Parent Unit and Nursery Unit. The Out of Range Indicator should alarm when the two units have lost connection and the Out of Range Icon will be visible in the Parent Unit screen. However these units sometimes require a "re-pairing" exercise to get them to communicate with each other again. Ensure both units have fresh batteries.
HOW TO RECONNECT THE PARENT AND NURSERY UNIT
In the unlikely event that the connection between the Nursery Unit and the Parents Unit is completely lost, please follow these steps to restore the connection:
1. Turn both the Parents Unit and the Nursery Unit OFF
2. Turn the Nursery Unit ON
3. Press and release the left wing 4 times. The nightlight will fl ash.
4. Turn the Parent Unit ON. A blue screen will appear with the NO SIGNAL icon in the Parent Unit Settings Bar
5. While pressing the TALK BACK button on the right hand side of the Parent Unit, press and release the POWER button on the left hand side of the Parent Unit
6. If successful, the video capture will appear on the Parent Unit's screen again. The connection was successfully restored
Jan 18, 2014 | Baby Gear
On one of our two parent receivers, it's showing 1 red light with 4 green lights above it. No sound at all. The other parent receiver works just fine, perfectly clear. I think my toddler was playing...
I had the same thing happen to one of my parent units over the weekend. The issue is that the parent unit lost the pairing with the nursery unit. Once I re-paired them, it's working great again. This is in the Troubleshooting part of the manual, but I've copied below for your convenience.
If Parent Unit won't lock onto the Nursery Unit, or you purchased a new Nursery Unit, follow the procedure below to pair the Parent Unit and Nursery Unit. If you purchased a new Parent Unit, skip Step 1. The new Parent Unit is ready to pair with your Nursery Unit.
1. Erase the Pairing from the Parent Unit. Turn the Parent Unit off. Hold the Volume Down Button on the Parent Unit while pressing the On/Off Button. Continue to hold the Volume Down Button until you hear a single beep and all of the Sound Lights illuminate briefly. Release the Volume Down Button. Press and hold the Volume Down Button again. Within 2 seconds you will hear a beep. Release the Volume Down Button. All of the SoundLights and the red Loss Connection LED will be lit. The Parent Unit is ready to pair with Nursery Unit. 2. Pair the Parent Unit with Nursery. Place Nursery Unit in the same room, five (5) feet (1.5 meters) away from the Parent Unit. Turn on Nursery Unit using the On/Off Button on the side. The green power light should come on. Within a few seconds, the Parent Unit will find the Nursery Unit. The SoundLights will shut off and the Parent Unit will beep. The Parent Unit is now paired with Nursery Unit. 3. Repeat this procedure if you need to pair another Parent Unit with the Nursery Unit.
Nothing happened when I turned on the Nursery Unit. What do I do? First try turning the Nursery Unit off, and then on again. If the Parent Unit still does not pair with the Nursery Unit, press the Channel Button on the Nursery Unit, then turn the Nursery Unit off, and then on again.
Hope this helps.
Feb 07, 2011 | Graco iMonitor Vibe Baby Monitor 2M16
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Both units are switched on but the parents' unit doesn't want to connect with the nursery unit. I clearly see the nursery unit's green light that flashed to detect movement and don't understand why my...
I have the same problem. I'm guessing mine is broken and will need to be replaced. However i did read a possible solution on a site with slightly different instructions to the ones in the box that describes how to pair the two devices together.
turn both the nursery and parent units off.
turn on the parent unit.
hold menu for 5 secs until it beeps.
turn on the nursery unit.
the parent unit waits for the signal then pairs.
if the nursery unit just waits 20 seconds then beep beep beeps and turns off i guess yours is broken too. I think its probably the nursery unit has stopped transmitting.
they will replace or repair a unit that less than 12 months from date of purchase with a supporting receipt.
the help line is 0845 009 1789 mon-fri 11-3pm
May 20, 2010 | Angelcare Baby Movement and Sound Monitor...
My parent unit is not working. All it does is flash when it's supposed to show me the pendulum swinging, room temp etc. I have forgotten how to reset it. Help please
Manuals here: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
Had same problem - here's what worked for AC401 (from manual):
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Oct 02, 2009 | Angelcare Deluxe Movement Sensor & Sound...
Dog Won't Have Her Puppies
Download Petza from sherlock software, search "Sherlock Software Petza". It makes it so you can make the babies born instantly. I have it on my petz game, and it works nicely. It also can neuter/uneuter your petz, trim family tree, change gender, send pet to door, and change the stats of your pet "Its Brain", this allows you to make them full/starving, baby/old, no fleas/fleas, not catnipped/catnipped, healthy/sick, ect.
Aug 07, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
HELP
you get new toys in minigames like the fantasy castle or as such. The nursery u can not go in it unlese your pet is with newborn
Apr 23, 2008 | Ubi Soft Catz 5 (Windows) (680901) for PC
Please help
If you want all the toys go on the internent then write sherlock software then download tinker then when downloads finshed open tinker then go on file then click on edit carry case then chose the toys you want then open petz 5 then all the toys will be there
Apr 23, 2008 | Ubi Soft Petz: Dogz 5 and Catz 5...
Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC Logo
310 people viewed this question
Top Ubi Soft Computers & Internet Experts
Pavel Pranovich
Pavel Pranovich
k24674
tony wahlman
tony wahlman
Are you an Ubi Soft Computer and Internet Expert? Answer questions, earn points and help others
