Question about Hotpoint VBXR1090D Top Load Washer
My washer overflowed and now it won't fill up with water or spin but it still aggitates how do i fix it?
  • 400 Answers
I am surprised that it agitates? The overflowing indicates that the water level pressure switch is not working. This is located at the back of the unit in the control panel. It looks like a round item with two wires attached as well as a plastic tube going down to the bottom of the drum. Try replacing it, I am sure this will sort your problem.
Posted on Nov 18, 2009
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
Washer won't aggitate, it will spin and fill up. there's also oil coming into bottem of tub.
there is a gear box sort of thing in the washer which in your case seems broken as the oil in the gearbox is pouring out..
you should get a professional mechanic take a look at your washer to fix it
Oct 26, 2011 | Washing Machines
My GE WCSR2090D top load washer has flooded our house in the past, and when looked at by a repair man he said nothing seemed wrong... so we continued to use it and it now leaks/floods only once in every...
You might have a partially clogged drain past your drain hose
(In the wall etc)
Thats overflowing behind the washer.
Watch the drain for a few washings and see if it overflows
It may be second or third or fifth load. Its hard to catch
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 08, 2010 | General Electric WCSR2090D Top Load Washer
Washer aggitates poorly when it is loaded
Check belt tension. Motor capacitors weak. Check the spin mode. Finally check the motor.
Apr 03, 2010 | Washing Machines
Will not aggitate or spin,
lid switch remove back panel switch on rt rear corner could have microswitch or fuse depends on mdl #
Feb 04, 2010 | Maytag Washing Machines
Washer won't aggitate or spin.
your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Feb 01, 2009 | Whirlpool LSR5132PQ Top Load Washer
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2009 | Kenmore 20722
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Hotpoint VBXR1090D Top Load Washer Logo
77 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
