Question about Canon PowerShot G10 Digital Camera
Hi, my canon g10 stopped working after months of
Hi, my canon g10 stopped working after months of buying it. canon say it is corroded due to water damage. i have not exposed the camera to any water at all. what are all the causes of corrosion and how long does corrosion take to set in? could this have happened before i bought it?
    President:
  • 1,871 Answers
Canon G10 will only take 3.99 gb of video, then shuts down. Has a 128 gb card so more memory is there. How to expand?
I'd take a look at the manual, but I suspect the maximum file size that it can record is 4gb. Actually just now I searched and found the Canon G10 manual, and it states "Max. Clip Size: 4GB". Also it states 1 hour limit also, whichever comes first. This is a common limitation due to the file system typically used (e.g. Microsoft's FAT).
Mar 21, 2017 | Canon Computers & Internet
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
The best telephoto lens for this camera?
Canon G10 - Ken Rockwell
www.kenrockwell.com/canon/g10.htm
Oct 20, 2008 - The Canon G10 is the best compact digital camera I've ever used, ...The G10 is a regular Canon Powershot point-and-shoot, in a tough ..... On the G10 theISO dial moves under the mode dial to make room for ... Neither the G10 or G9 have true zoom lenses; they only change focal length in discreet steps.
Canon PowerShot G10 Review ' Digital Camera Resource ...
www.dcresource.com/reviews/canon/powershot_g10-review/
Nov 24, 2008 - Is the PowerShot G10 the ultimate compact camera? ... Telephoto lens, TC-DC58D, From $109, Boosts focal range by a factor of 1.4X, ..... For bestresults, you'll want to attach one of the Canon Speedlites I mentioned back in ...
Jan 01, 2016 | Canon PowerShot G10 Digital Camera
Canon g10
No. The LA-DC58K only allows you to use the TC-DC58K teleconverter with your camera.
The Tamron 28-200mm lens is intended for use with SLR (single-lens reflex) cameras, not with point&shoot cameras. As far as I know, there aren't any adapters which will allow you to use an SLR lens with the G10.
A teleconverter is an add-on accessory that works with an existing lens. The 28-200 is a lens, which is intended to be used as-is. Using it on the G10 would basically require removing the built-in lens on the G10. As that lens can't be removed...
Jan 05, 2014 | Tamron Cameras
I have an 2001 dodge durango that i have had to change the whole back tail light due to the break light not working we have tried new bulbs, fuses, sockets this is the third time it does this...we buy a...
Does your Durango have trailer wiring installed, and if so, was it factory installed or installed aftermarket? If installed aftermarket, there's a really good chance your wiring issues are due to incorrect connectors being used to tap in to the factory wiring which has allowed water and other elements to corrode the wiring, causing an intermittent connection.
Dec 23, 2017 | 2001 Dodge Durango
When i connect my canon powe shot G10 to my computer the camera comes on and says comunication error
Having gone nearly two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
Aug 17, 2011 | Canon PowerShot G10 Digital Camera
I can't download anymore my photos from my Canon G10 to my computer.Before I could.
Having gone over two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
Jun 11, 2011 | Canon PowerShot G10 Digital Camera
My canon sureshot g10 will not turn on with a good battery. Could it be fuse? How do I replace?
hi It could be fuse in some case. Other is main pcb brown. There is fuse in dc/dc convertor circuit which distribute power. The cause due to fall out screws from strap holder inside of camera. You can check it with multimeter. But there is possible risk. If you wish to work. let me know I will let you work.Also, if main is bad then you should send to canon factory. your local repair shop can not provide service due to reprogram by computer. Thanks and best regard!
May 25, 2011 | Cameras
HAVE LOST DISC FOR MANUAL CANON G10
You can download the required manual from:
Canon G10 Download Support
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
Sep 29, 2009 | Canon PowerShot G10 Digital Camera
Canon G10 wont turn on
Try removing the card first and then trying to power up the camera. Cameras often fail to turn on/off when a card goes faulty. Next I would try pushing the playback button, it also acts as a power button but starts the camera in playback mode. If this works it could indicate a problem with the power switch circuit itself. If there is still no sign of life I would suspect a fuse to have blown. They are internally located and very small, you would need to have a service centre try replace it for you. Good Luck!
Apr 13, 2009 | Canon PowerShot G10 Digital Camera
Canon PowerShot G10 Digital Camera Logo
293 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
