Question about Dell Latitude D600 Notebook
Power button pressing power button will not turn compter on i get flashinng lock lights.then i let it rest for 4 or 5 hours i press power button works fine for five minutes or so,then computer freezes.
You have faulty motherboard my friend.Time to get new laptop as it is expensive to change mb
Posted on Nov 11, 2012
  • Dell Master
  • 497 Answers
1. First turn OFF the Computer and disconnect the AC Adapter from the Computer.
2. Remove the Battery from the Computer, clean the Battery contacts with the pencil eraser.
3. Insert the Battery in the Computer after 5-10 seconds and try turning ON the Computer with the Battery power only (without connecting the AC Adapter).
4. If the issue persists, remove the Battery, connect the Computer with the AC Adapter and then try turning ON the Computer using the AC Power only.
5. Remove the RAM Module from the Computer, clean it, insert the RAM in the Computer and then try turning ON the Computer (either with the AC Power only or with Battery only).
6. Try connecting the AC Adapter to different working Power outlet.
NOTE: If you are getting any error message or any beeping noise then please post it for further troubleshooting steps.
Good Luck!!!!!!!!!!
Posted on Nov 18, 2009
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
How to set clock in radio on a 2014 Jeep Patriot
Clock Setting Procedure 1. Press and hold the TIME button until the hours blink. 2. Adjust the hours by turning the right side TUNE/ SCROLL control knob. 3. After adjusting the hours, press the right side TUNE/ SCROLL control knob to set the minutes. The minutes will begin to blink. 4. Adjust the minutes using the right side TUNE/ SCROLL control knob. Press the TUNE/SCROLL control knob to save the time change. 5. To exit, press any button/knob or wait five seconds http://www.chryslercommercialvehicles.com/jeep/download/pdf/manuals/2014-Patriot-OM-1st.pdf page 240
Mar 12, 2015 | 2014 Jeep Patriot
Set clock 08 fxdwg
Turn the ignition switch to ACC or IGNITION, press the function switch until time (hour and minutes) is displayed. Press and hold the function switch for five seconds or until 12HR begins to blink in the speedometer display window. Then release the button. THEN press and release the function switch once to advance to a blinking 24HR or military style time display. Then each time you press and release the switch, the display will change from 12HR and 24HR. When the desired time is displayed, press and hold the function switch for five seconds and the display will switch to the time display with the hours blinking. There is NO AM/PM setting. Press and release the function switch repeatedly to advance the hours to the hour you want. It will advance by one hour with each press of the switch. WHEN the desired hour is displayed press and hold the function switch for five seconds and the minutes display will appear and blink. THEN press the function switch repeatedly until the desired minutes display is attained (the minutes value will change by one minute for each switch depression) and then press and hold the function switch for five seconds and the minutes display will stop blinking which indicates that the time has been set. Turn the ignition switch off and the time you set has been saved and will change as time passes.
May 02, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
How to reset clock on 2010 softail deluxe?
Apr 26, 2014 | Harley Davidson FLSTN- FLSTNI Softail...
Keypad door lock does not work..?
it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
  • Enter the permanent factory code.
  • Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment. To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s). To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) . To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.) This will turn off courtesy lamps and arm anti-theft alarm control (if equipped). To program an alternate code:
  1. Enter the five digit permanent entry code into keyless entry keypad .
  1. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
  1. Enter any alternate five digit code within five seconds of pressing 1/2 button.
    • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
      • 9/0 — no memory recall
      • 1/2 — memory seat position 1
      • 3/4 — memory seat position 2
      • 5/6 — memory seat position 3
    • After successful programming, the doors will signal by locking and then unlocking.
  • Keyless Entry Keypad Does Not Work Properly
  • Circuit.
  • Keyless entry keypad.
  • Electronic door lock control processor.
  • Open Fuses:
    • Town Car and Crown Victoria/Grand Marquis
    • Power Distribution Box (under hood)- K, 40A (Maxi)
    • Instrument Panel Fuse Panel - 17 (10A), 10 (20A), 8 (15A), 5 (15A) and 4 (10A)
  • Loose Connectors
  • Corroded Connectors
  • Oct 04, 2009 | 1995 Lincoln Town Car
    Does anyone have instructions for Nike Imara Fit WR0076?
    How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
    PLEASE READ CAREFULLY
    STEP 1:
    First hold the button for set/light.
    STEP 2:
    wait for the "hold to set" message to appear
    once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
    TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
    STEP 3:
    To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
    *If you are done setting the time press the set/light button, and there you have it.
    If you still need to change the minutes of your digital watch proceed to step four.
    STEP 4:
    After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
    To set MINUTE:
    press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
    *If you are done setting the minute, press the set/light button, and there you have it.
    If you still need to change the date specifically, the day of your watch proceed to step five.
    STEP 5:
    To set date, specifically, DAY:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
    To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
    *If you are done setting the day, press the set/light button, and there you have it.
    If you still need to change the date specifically, the month of your watch proceed to step six.
    STEP 6:
    To set date, specifically MONTH:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
    To set MONTH:
    press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
    *If you are done setting the month, press the set/light button, and there you have it.
    If you still need to change the date specifically, the year of your watch proceed to step seven.
    STEP 7:
    To set date, specifically YEAR:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
    To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
    *If you are done setting the year, press the set/light button, and there you have it.
    If you still need to change the 12/24 hour format of your watch proceed to step eight.
    STEP 8:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
    To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
    *If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
    If you still need to change the power hour of your watch proceed to step nine.
    STEP 9:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
    To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
    Press set/light to set POWER HOUR.
    May 13, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
    How do I set the time for nike imara fit WR0076-002 wrist watch?
    STEP 1:
    STEP 2:
    STEP 3:
    STEP 4:
    To set MINUTE:
    STEP 5:
    STEP 6:
    To set MONTH:
    STEP 7:
    STEP 8:
    STEP 9:
    Mar 26, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
    I dont know how to set the time
    STEP 1:
    STEP 2:
    STEP 3:
    STEP 4:
    To set MINUTE:
    STEP 5:
    STEP 6:
    To set MONTH:
    STEP 7:
    STEP 8:
    STEP 9:
    Nov 11, 2008 | Nike Imara Run WR0075-014 Wrist Watch
    Setting the date and time on watch
    time:
    hold left button -- hour will appear and begin flashing.
    press right button to set.
    press left button to advance to minutes, press right to set.
    date:
    press left -- date will appear. now hold left until day flashes.
    press right to set.
    press left to advance to month, right to set. then same again for year.
    Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
    Whirlpool Flat top Accubake self clean 24 inch
    Of course - Empty the oven and clear off around it.
    The AUTO-CLEAN cycle time is adjustable, from 2 hours
    30 minutes and 4 hours 30 minutes in 15-minute increments.
    Suggested clean times are 2 hours 30 minutes for light soil and
    4 hours 30 minutes for heavy soil. The last 30 minutes of the
    cycle is for cool down.
    To Self-Clean Using AUTO-CLEAN
    1. Press AUTO-CLEAN.
    2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
    desired self-clean cycle time.
    3. Press START.
    The oven door will automatically lock. The “DOOR LOCKED”
    and “CLEAN” indicator lights will be displayed. The time
    remaining will also be displayed.
    4. When the self-clean cycle is complete and the oven cools,
    the “DOOR LOCKED” and “CLEAN” indicator lights will turn
    off.
    5. Once the oven is completely cooled, remove ash with a damp
    cloth.
    To Delay Start Self-Clean Using AUTO-CLEAN
    2. Press the TEMP/HOUR “up” and “down” arrow pads to set
    the desired self-clean cycle time.
    3. Press START TIME.
    4. Press the TEMP/HOUR “up” and “down” arrow pads to set
    the desired start time.
    5. Press START.
    The oven door will automatically lock. “DOOR LOCKED” and
    6. When the self-clean cycle is complete and the oven cools,
    off.
    7. Once the oven is completely cooled, remove ash with a damp
    cloth.
    Owner, Warranty, Installation and Parts manuals are here:
    http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
    Sometimes search links don't work when copied.
    Here is the direct link to the Use and Care Guide:
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
    Page 16 has the above instructions.
    God Bless!
    -Ptochos
    Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
    Dell Latitude D600 Notebook Logo
    124 people viewed this question
    Alun Cox
