Question about Radio Communications
No sound Cobra 25 LTD Classic. I have power to unit. The mic keys high just not sound. My Cobra 25 NW ST was in a vehicle that developed a bad voltage regulator.  A large overvoltage problem caused the vehicle's battery to boil and the headlights to blow.  The CB was on at the time and it's inline fuse blew.  Upon replacing the fuse (and trying the CB in a different vehicle) the CB powered up and "appeared" to work with the exception of received audio.  With my ear close to the speaker I can hear received voice but there is no audio gain whatsoever.  Varying the controls has no effect.  Do you think the audio amplifier was blown?  I opened the unit and can see no "Visual" indications of a problem. Thanks, Mike
  • 1 more comment
  • trippleDDD Jul 17, 2008
    uniden Pro510xl . I have no sound coming out of radio speaker or external speaker plugged in on an active channel. AND when i key the mic, the modulation meter jumps up but then falls right back down to no reading. i've tried different mics and speakers to no avail. i have 3.5 watts power output but no audio in recieve AND transmit....
  • mikey1008 Jan 03, 2009
    Im having trouble with the receive I can transmittt very well but i cant pull in units that are fairly close i have the rf gain all the way open I thinking that it needs to be adjusted so how do i do this ?
  • 93mustanglx Mar 24, 2009
    what mod chip is in a year 2001 cobra 25 nw ltd classic? is it a ta7222ap. and where can i order just one for cheap? i have the same problem. when i touch the leads to the chip i get sound for a few seconds and it fades out and the chip starts heating up
  • 37 Answers
Yes It sounds as though the audio amp may have taken the hit go to this link and download the service manual it will give you voltage info http://www.cbtricks.com/radios/cobra/25ltd_st_25wx_st/index.htm ...Chia
P.S. If you have an external speaker plug it in to the PA hole on the back put the radio on PA and see if you get any sound then if the dynamike is turned up it will be LOUD.If not I would replace the audio amp.If you need one let me know and ill directc you in the right direction...Chia
Posted on Jan 11, 2008
What is the mic wiring for 636l to cobra 25 wx nw st
If you have not bought it yet some dealers may have them already set up.Cobra is a popular radio so before you buy ask. you could just match it up to a cobra 25 mic though.
Mar 14, 2013 | Cobra 25 WX-NW-ST 40-Channels Base CB...
I have a cobra 25 nw st and it will not transmit
Hi, my name is John. Welcome to FixYa. Turn your MIC GAIN or DYNAMIC to MAX. Try another mic on it , if that does not do the job, let me know I will have further. Thanks for choosing FixYa. good luck John
Oct 30, 2010 | Cobra 25 WX-NW-ST 40-Channels Base CB...
We have a Cobra 148 nw st Sound Tracker When
It could be..
Final blown : worst case
bad mic : try another one
CB/PA switch on PA instead of CB
CB/WX swithc on WX instead of CB :you cannot transmit on weather.
Broken wire on mic jack.
Try the mic and switches first, and if that doesn't help you may need to take to tech. You can find one at a cb shop usually at truck stops.
Oct 27, 2009 | Radio Communications
NEED HELP WITH MIC WIRING FOR COBRA 25 LTD ST
1 Shield 2 White 3 Red 4 Black if the radio keys up as soon as you turn it on reverse 3 and 4 I am not familiar with that mic.But the way I actually should have given you the wiring order is as follows:1Shield 2 Modulation 3 and 4 key up I hope this helps.
Feb 18, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
COBRA 29 NW LTD CLASSIC
Capacitor C-82, which connects the output of the driver to the input og the final, is leaky or shorted, putting +12 volts on the base of the final, which blows it immediately.
Mar 28, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Codra 29 nw ltd classic
For the money,the Cobra 29 nw/st is just as good if not better than a Galaxy. Cobra is more durable by far. I have had 3 of these cobra's in the last 30 years. Only had to replace the last one because the tractor got hit by lightning.
Sure would not pay big money for a name.
Mar 19, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Mar 12, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
No sound
The Cobra 25 requires the mic to be working for any sound to come out. My suggestion is that you first try a new mic. If this doesn't work, look real close at the board on the soldered side ( around the if section, thats the area that right under the waxed area on the component side of the board ) for cold solder joints ( broken lead solder) You may need a magnifing glass. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 17, 2007 | Cobra 25 LTD 40-Channels Base CB Radio
Radio Communications Logo
466 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
