Question about Sanyo Televison & Video
Headphones sound isn't there when I plug into the audio jack
Audio plug is a computer souncard input, not an output connection.
Posted on Nov 18, 2009
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
No Speaker Sound, Thinks Headphones are Plugged in
If you don't plan on using the headphones - take the cover off and there may be a cable to the headphone jack board that can be unplugged. This will disable the headphone jack from sending a bad signal to the micro. If you want to be able to use the headphone, then the jack is going to have to be replaced.
Jun 16, 2013 | Pioneer VSX1020K Receiver
No sound in headphones
Could be that your audio jack has material stuck in it or possibly the jack is bad.
Mar 07, 2013 | Motorola Mobility Electrify
Denon 1908 no sound
Try inserting a headphone plug into the headphone jack and remove it. Sometimes these units have a problem in the headphone jack where the unit thinks there are headphones plugged in even when there isn't. This cuts all the audio output to the speaker jacks. If you never plan on using the headphone jack, you can also go inside of unit and unplug the cable that goes to the headphone jack board. Just make sure you unplug the unit before you do this, the plug is close to the main power switch.
Feb 22, 2013 | Denon AVR-1908
I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
Aug 14, 2011 | Audio Players & Recorders
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Televison & Video
How do I wire up my Logitech X540 Speaker system to my Lg tv?
Most TV's nowadays, have audio out RCA jacks that will allow you to send audio from the TV, to an alternate source. These speakers do come with an adapter that allows you to hook up RCA red and white audio cable, and plug them into the adapter, which goes from the RCA jack to a 1/8 in female headphone style jack. You would then need to get a 1/8 in audio cable that has two male ends, and plug that into the back of your sub woofer in the front speakers port. But this really isn't going to give you very good sound quality being it's not giving you true 5.1 surround sound, even with the matrix feature enabled!
Dec 27, 2010 | Logitech X-540 Computer Speakers
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
No sound output from rear speaker jack
Plugging headphones into the computer will disable sound output from the sound card by design.
Sep 15, 2007 | Acer Aspire L100 PC Desktop
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
