My lap top (IBM Think Pad t30) won't turn on
When ever i turn on my lap top, it turns black and beaps 8 times, then nothing happens. I can't do anything. I tried pressing on bottuns, but it reamains blank as if it's dead.
Can you please tell me what's wrong, and how i can fix it?
pleese and thank you.
  • 2 more comments
  • marinaten Jan 10, 2008
    it was dropped a couple times by the kids..
    ok thanks..so should i open it up, see what's loose?
    thank you very much!
  • R-aphid Apr 06, 2009
    My IBM Think Pad, it seems, turns on on its own will. At times it would work just as a normal laptop does but on other occassions I'd have to sit there and plead with it to start working by pressing the power button time and again. Yes, and very many a times it shuts down on its own and starts again only after its battery gets a good beating. I am totally lost.
  • 589 Answers
Sounds like the RAM or the CPU has come loose. Was it dropped or banged around (like at an airport)?
Posted on Jan 10, 2008
6ya staff
SOURCE:
Ibm think pad bios locked
Short pins on the bios chip. I have done this on T42's. I assume it will work on T30's as well. You'll have to search the internet for which pins to short (usually pins 5 & 6 or pins 7 & 8), but you short the pins together and turn the machine on. Be careful! Do it at your own risk. Once you are into the BIOS, you cancel the password settings and save.
Jan 24, 2014 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 2366 won't boot after the IBM Thinkpad screen
you can go to the BIOS setting? if you can,look for "Boot Device Priority" or something like that,it's usually placed on Advanced settings. Set the first boot device as your harddisk,save the settings and restart your computer
Please let me know if it's working or not
Aug 28, 2012 | IBM ThinkPad T30 2366 Notebook
My IBM T30 Think pad lap-top is stuck in power save mode.The battery is still charging fine,but the whole screen is black with no image when i turn it on.However when i switch it on,all the leds light up...
Try to power drain the motherboard.
please follow this steps:
take out the battery
unplug the power adapter
press and hold power button for 30 secs
put everything back in
power on the computer
if issue is not resolved. There could be a possibility that this is LCD problem.
May 21, 2010 | IBM ThinkPad T30 2366 Notebook
I can not detach my IBM Think pad 2662 lap top from the driver
I had the same issue. Here's what I did. Not sure if it will work for you. But give it a try.
1) turn on the machine and press "F2" to go into set up.
2) Press alt-p seven times to go to the last page.
3)Press the down arrow to highlight HDD password. Set a password as instructed and reboot the machine.
4) You can remove this password later once your machine starts fine.
Even if you didn't get try this too.
1. Make bootable CD which contains Norton Ghost or other disk image software
2. Boot your system using bootable CD with Norton Ghost software, u can use Hiren's CD ISO image. If u don't know about hiren just google it.
2. Once you boot up , open Norton Ghost click LOCAL-> PARTITION->FROM IMAGE
3. Now "look in" for "[DellRestore]FAT drive" and select this drive (this is recovery partition)
4. Now go to "IMG" folder and select FI.GHO file
5. Click Open and there you go... Process started
Jan 28, 2010 | IBM ThinkPad X20 2662 Notebook
I have a T30 IBM Think Pad and cannot find the wireless switch. Can someone help me?
I don't think the T30 has an actual physical switch for the wireless. The ThinkPad button will show you how to do the wireless setup/repair. If you have Bluetooth on it, the Bluetooth indicator should be near the hinge.
Feb 24, 2009 | IBM ThinkPad T40 2373 Notebook
Laptop will not turn on
It seems that you are out of luck. If the power cord does not fix it, the next possible cause would be the main board. Unfortunately, those are usually expensive. If i was in your shoes, I would try to return the power cord and invest the money in a new computer.
Good luck.
Dec 02, 2008 | IBM ThinkPad T30 2366 Notebook
Charger pin is plugged in but it doesnt charge neither does the charging lite turn on any idea? can be it a problem with BIOS ?
This is a common problem with the T20 & T30 series Thinkpads. The problem is with the power management chip on the motherboard. The pm chip regulates & controls the power input & usage, allows the machine to switch from AC to battery, and controls the charging. Unfortunately, you will have to replace the motherboard in order to fix it.
Jul 26, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 2367 beeps 8 times
It's your memory, or more to the point, the memory slots. take all memory out, install 1 piece in the slot closest to the back of the laptop, push down on the memory as if pushing it into the motherboard, and hold pressure while booting.
Bet that works. if not, let me know.
I've got the same machine.
Good luck
Jan 03, 2008 | IBM ThinkPad T30 2366 Notebook
Ibm t30 2366
hi ye check your ram and cpu is 100% if the cpu is disloged it will not come on..try this for starters..
Nov 20, 2007 | IBM ThinkPad T30 2366 Notebook
Open Questions:
SBCglobal MAil TecHNicAL ?{1-/855+/*+536/*+5666/}#[email protected] SuPPoRt NuMbER SERVICE call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 12, 2019 | Best Computers & Internet
SBCglobal MAil TecH $%{1^/855/^536^/5666}#[email protected] SuPPoRt NuMbER MICHIGAN call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Computers & Internet Logo
415 people viewed this question
Ekse
Marvin
Marvin
