My dryer would not heat up. I took it appart and it appears that the heating coil is broken. Part # 407685 but this has both the heating element and rear housing assembly. CAn I replace just the heating coil?
jsrock516
  • 5911 Answers
SOURCE: Kenmore Dryer
If you go to searspartsdirect.com, type in your model number in the Search menu, then look under the "Bulkhead" menu option, you will see an illustration of your dryer. You will need to remove the heater box cover (item #5) to get to the heating element. The element should slide out of the bottom of the heater box housing. Removing the housing from the dryer first makes it easier. Sometimes you may need a little muscle in getting the heater coil to come out.
Have you checked the thermal cut-out(TCO)/hi limit thermostat? This is item #1 in the drawing. If your dryer runs, but does not heat, this is normally the culprit. You are right to assume you could have a heating element problem, but the element tends to be more resilient. In my experience with electric dryers, the thermal cut-out tends to go bad first. It's easier to check and easier to replace as it is mounted on the outside of the heater box. Check for the following:
With the heater box STILL installed, the TCO will be a small component mounted at the top of the heater box housing. The hi-limit thermostat will be mounted at the bottom of the heater box housing next to the ceramic terminal of the heating element. With the dryer UNPLUGGED, disconnect the wires to the TCO and do a resistance reading. It should read 0 ohms if good. Do the same with the hi-limit thermostat. It should also read 0 ohms if good. Last of all perform a reading across the leads of the heating element with the wires unplugged. You should get a reading of 9 - 13 ohms if it is good. If you determine the TCO or hi-limit thermostat to be bad, it is HIGHLY recommended that you replace them BOTH at the same time. They are sold as a set (part #279769). Failure to replace both components could result in part failure. The part number for the heating element is 4391960. I hope this helps you.
Posted on Mar 17, 2008
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
docjohn174
  • 943 Answers
SOURCE: Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Posted on Sep 15, 2008
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Posted on Jan 02, 2009
  • 188 Answers
SOURCE: dryer will not heat
Check to make sure you have 240V at the outlet. If you do, check the continuity of the element and thermostats. If still no heat, it could be the temperature setting switch, the timer or the motor.
Posted on Feb 21, 2009
My dryer is not heating at all where to I find the thermostat and coils? Thank You
Most dryer heating elements are incased in a metal type box behind the dryer. It looks like the size of a shoe box for the most part, the heating element or coiled wires are inside that box, most of the time the coil wire breaks and will not get red/hot and will not heat at all. I've replace the heating element on my dryer, wasn't that hard to find and remove and examine that the coil was broken not making contact any more.
Mar 05, 2015 | Dryers
No heat in my compact dryer.
there is only 1 reason as to the unit still running but not heating if its running then all thermos must be intact so it has to be the heating coil take the unit appart make sure the two heating points still have the cables attached if you can do a polarity test on the element that will define its blown then replace the coil in most cases when the coil blows you can see a burn mark were it did
best luck
please take the time to rank this advice
merry christmas
Dec 22, 2010 | Avanti Dryers
It will not heat up. Barrel turns, but does not produce heat.
best luck
merry christmas
Dec 08, 2010 | Dryers
Dryer is running fine but no heat????
best luck
merry christmas
Dec 07, 2010 | Kenmore Dryers
The dryer is not drying the clothes
best luck
Dec 02, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer works but doesnt get hot to dry clothes
best luck
Dec 02, 2010 | Roper REX4634KQ Electric Dryer
My dryer seems to work ok but the heating element doesn't come on.
heating element is out to reach element either remove bottom lid below door you should be able to see element you can see heating coil some are on the back of dryer and some heating are around drum a element may be broken,call repairman
Nov 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Electric dryer...turns on, runs...no heat
heating element is bad unplug machine access the heating element it should have a break in the coil if so twist the coil back together gently though put it back in and try it i didi it to minr 6 years ago and no problems and you save a ton of money.
Mar 16, 2009 | Dryers
Wirlpool dryer heating poorly
Make sure you have got it set to full heat and not half heat, you may have a faulty heat selector switch.
Dec 09, 2008 | Dryers
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
