Question about Freezers
The lid switch on my kenmore 70 series has broken off. The wires are still attached, but the plastic unit is no longer connected to the underside of the machine top. I need to drain the machine somehow in order to fix it. How do I do this with the lid switch broken?
  • 400 Answers
There are two wires attached to the lid switch, just connect them together and the machine will work as normal. Please take care not to open the lid while it is operating. This switch is a safety cutout.
Posted on Nov 18, 2009
The chest freezer was open wide for 24 hours before I noticed it. Will I have a problem with the unit or will it be fine
as cold air sinks to the lowest point it would have been operating a little longer that if it was closed I would think that it will be fine
example chest freezers in supermarkets only have plastic sliding lids and the ice creams and other frozen foods are still frozen
Apr 28, 2016 | Freezers
Holiday chest freezer lcm070lc
There are only three wires, aren't there? One is a safety earth, probably green or green and yellow. It goes on the spade attached to the metal of the thermostat body. The other two are a live and switched live. They go on the two spades that come out the plastic body. If there happens to be a third, it will be an alarm signal wire. Connect in any order you like. If the compressor comes on and the signal light, all is well. If the signal light does not come on, and the compressor switches off at -12c swap 2 of them. If none of this happens, switch 2 of them.
Apr 21, 2014 | GE Freezers
The "door ajar" alarm keeps going off and the door is sealed shut?
Your door switch may be bad. Is the light on when you open the door when you manually push in on the switch does the light go off? On most fzr the door ajar alarm is set off by the door switch showing the door is open.Turn off the power by unplugging the fzr then you can pop the switch out with a flat blade screw driver if it is only a two wire you can use a paper clip to connect the two wires wrap them with elect tape Then plug the freezer back in and see if the problem clears if it does order a door switch. Some units use a vacume sensor but i believe all kenmores use the door switch. good luck
Aug 17, 2010 | Kenmore Freezers
Water coming out of the lid of a Kenmore 5 cu. Freezer
Funny. We just spent an hour trying to figure out the same problem with our Kenmore. It is the third or fourth time that we've noticed water on the floor under the freezer, but the first time that we've been able to track it to the lid.
The only thing that makes sens to me is that this problem may be happening when our freezer has a frost buildup around the top of the unit which doesn't allow the lid to close perfectly snug. I'm thinking that this causes a bit of melt in whatever frost may be inside the lid from regular air circulation around the unit. It runs out the back of the lid when it opens.
Check that there is no frost around the rim of the freezer that may be causing a slight (it only takes a very small opening to allow warmer air to circulate under the lid) irregularity in the lid seal.
Jul 06, 2010 | Freezers
Kenmore 70 series stopped in the draining cycle with water still in tub. Won't function in any cycle now. Lid was down so I don't think lid switch.
You need to remove drain pump and clear restriction. once done, you should be able to continue to wash again.
Nov 12, 2009 | Freezers
Chest freezer lid repair
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
INSULATING A FREEZER LID
you can put insulation over the wires no problem at all, the insulation it would have been is prob styrean. you can buy it in different thickness sheets
Nov 13, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
91 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
