Question about Compaq Evo N610C Notebook
Unable to get PC to boot
The pc was working normally until Sunday night. I switched it on as usual , the Compaq screen came up followed by another screen apologizing for the inconvenience etc and gives a number of options including start windows normally. I tried this and I get the windows screen, a quick flash of a blue screen, then it goes back to the Compaq screen and then the "We apologize" screen.
The message on the blue screen says "Unbootable Mount Volume", what does this mean and how do I get the PC to work?.
  • 3 more comments
  • Mikestaff Jan 11, 2008
    Thankyou for the suggestions, unfortunately XP came pre-installed so I don't have any discs, not even the recovery discs.
    It doesn't have a floppy drive, just the cd/dvd drive.
    Hi nitrotrike, unfortunately I don't have the XP disc, the OS came pre-loaded.
  • Luggy1992 Jan 12, 2008
    What if you can not even open the cd drive to put the cd in what do i do then
  • Mikestaff Jan 16, 2008
    I was able to borrow an XP disc, but the laptop won't read it, the drive spins, but that's it. The disc works on other Pc's, any ideas?.
  • Mikestaff Jan 21, 2008
    I am able to put the disc in the drive, but the pc won't read the disc, even though the disc spins.
  • 589 Answers
Does it have a floppy drive? if so, check if there is a floppy disk in the drive.
Let me know, and we can go to the next step.
Posted on Jan 10, 2008
  • Anonymous Jan 11, 2008
    unmountable boot volume means that either your system is corrupted, your boot.ini is damaged, or your boot sector is corrupt. Try this:
    "You can boot to the XP cd and when you see the Welcome to setup press the letter R
    You will get a dos prompt
    Then type "chkdsk /p" without the quotes and hit enter
    When that is done type "fixboot" and hit enter
    "Y" and enter at the prompt
    Then type "exit" and hit enter
    The system will now reboot into Windows"
  • 520 Answers
I had the same prob with my brothers laptop the other day.
to fix:I put copy of xp in drive and booted up pressing F8 to choose option start from cd.
when setup starts instead of choosing repair disk choose setup new.once system analyses that there is already os installed ;choose repair .this roughly about the same time as install fresh copy only it has your previous personal files and software still intact.this way works.trust me.
  • Anonymous Jan 13, 2008
    you can use any xp disk.make sure you have the key though.you also may have to register again,but at least youll have all youre programs.
    im sure you know someone who could lend you a copy;you only need it for an hour.
  • Anonymous Jan 21, 2008
    with regard to cant open cd tray.if yiu know that the cd drive works ok but you cant open it ;stuck jammed...whatever....
    you get a short piece of wire( like a safety pin) and insert and push it in a slot usually next to the open button on the cd tray.
    with some models of cd/dvd drives you get a piece of wire with the package for this purpose alone.
6ya staff
SOURCE:
PC Compaq Presario S5160UK boot problems
From the description you have given, I would suggest that you re-install the operating system(Windows) make sure you save any thing on the computer that you can't live without. (Music, photos and videos). You will need to do a format of the hard drive. As you may have an unknown piece of malware or just a badly corrupted operating system.
Jul 22, 2013 | Computers & Internet
Compaq presario cq70 wont boot up
old Compaq (now HP)
https://h30434.www3.hp.com/
first screen died, now wont boot, to external VGA monitors.
Fn+F4, sure. the external command key. sure
ok VISTA, first time any one tells what OS is there, wow.
step one on all PCs lap or desk top is what,
does the screen show any text at all?
like Hit Esc to enter setup or BIOS>
we first see of BIOS is alive. it not the PC is DEAD.
zero text means DEAD PC> and NO BIOS means DEAD PC
so out comes that old useless LT battery.
useless as in , if its original its bad. most are.
you skipped step 1 here, (battery out)
and next fans work? and blow air, no lint packups. inside.
learn that PC's go dead, with overheat, can happen fast.
http://pcdied.com/black-screen.html#Laptop
Jun 28, 2017 | Compaq Computers & Internet
Video screen will not display after pc goes thru it start up sequence. But during start up process will display window welcome page
Try restarting the computer in safe mode and when it boots, see if the screen is visible. If it is then there is an incompatible screen resolution that is trying to be displayed in normal mode. Set the default screen resolution to one that you know works with the adapter....usually 800 X 600 is safe until you get a normal boot. If you have video during the booting process than I do not believe it to be a hardware problem, usually windows driver or a setting.
Aug 31, 2009 | Computers & Internet
My EVO 510 has been operating fine until last night when I entered my password resume from screen saver, the machine did not return to the desktop and just hung with a blank screen. I powered off teh...
Click Start>Run and type msconfig. Select the startup tab and deselect everything. Reboot your computer and attempt to log into Windows. If you are successful you will need to access msconfig and re-enable programs systematically until you find the culpret.
Best Regards.
Jul 15, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Reformat
(A) Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how: 1) Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.). Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
if it dont this is the procedure given below to format the whole operating sys 1) Put the CD in the CD drive and turn the computer on. 2) As the computer begins to turn on, you should see the message "Press __ to enter setup" (it's usually F1, F2, or F4 - models vary). Press that key.
3) You should then see the Setup screen for the BIOS ("Built-In Operating System") - using the arrows, find the "boot disk priority" settings and select your CD Drive as the first priority.
4) Exit setup, saving changes (usually by pressing F10). The computer should then boot normally using the CD.
Jun 18, 2009 | HP Compaq Presario v3000z Notebook
Compaq presario 1700 with windows me
will it work while on battery power if it does it might be over charging or maybe it is getting to much voltage though the ac adapter i done some research on this and seems this is a issue with this model try this find a friend or someone that has an ac adapter and switch out just to see this maybe the cause
Mar 23, 2009 | Compaq Presario 1700 Notebook
Have a compaq 5304, and it will not boot up, it acts like it then it goes compaq page and continues to redo that until I shut it off
your pc is re-booting, the quickest way to solve that prob. is to restore the pc, (hope you have or made the restore disk.) just insert the cd into the drive and re-boot. follow the on screen instructions to restore your pc.email me at [email protected] and let me know if you got it going.
Jan 05, 2009 | Compaq Presario 5304 (120969-004) PC...
Not able to open windows
Sounds like a hard Drive problem. A virus actually. The Best thing to do if Safe Mode Failed is the Repair Your system, to do this insert your XP CD and wait until it says 'Press any key to boot CD' Press any key and follow instructions to repair windows. If it works, run a virus scan immediately. If Not, take it itno a computer technitian to look at it if you want the stuff on your Hard Drive, of if you feel you don't care too much just wipe the Hard Drive and Re-Install Windows XP. just do the same thing as repair but instead follow the instructions for Installing XP and choose either Clear or Erase Hard drive if you don't want the info or choose don't clrear or Erase if you really want stuff from your hard drive, But run a Virus scan Immediately asap.
Hope This Helps
Nov 18, 2008 | Compaq Presario M2000 Notebook
Windows 2000 Pro Armada M700 Boot Up Problem
plz check is there any option for start your computer in last known good configuration if yes then you try it. you will get in safe mode screen
Jun 30, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
HOW TO BOOT
While your computer is booting up, when the manufacturers screen comes on, press and hold F2
Jan 28, 2008 | Compaq Presario X1000 Notebook
Compaq Evo N610C Notebook Logo
679 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
