Question about Nokia 5300 Grey Cellular Phone
Blutooth not communicating nokia 5300 bluetooth not communicating
My name is rajkumar yadav. i have nokia 5300 express music phone. my phones blutooth is not working. it is not searching any bluetooth devices.
Hello sir.
first of all set visibility of your phone as "permanent visibility" .
Then switch on bluetooth of your phone.
Clear the paired devices list and have another phone having its bluetooth switched on.
If even then your phone do not search the device then switch off bluetooths of both the phones and then again switch on both the bluetooths and search the device. Thanks.
Apr 08, 2011 | Nokia 5300 Grey Cellular Phone
MY 5130NOKI BLUETOOTH IS NOT WORKING PLSS GIVE SOLUTION
Nokia 5130 is an old phone and haven't got a bluetooth, it only has IrDa (infrared).
Mar 05, 2011 | Nokia 5130 Cellular Phone
My nokia n82 bluetooth is written unable to connect when i tend to send or receive file
first check ur bluetooth menu and ur bluetooth visuability ......................................................
if the visibility was hiden position change it to shown to all location ok...........................
Dec 23, 2010 | Nokia N82 Handheld
My nokia 5800 bluetooth is not working. when bluetooth is switch on then it display the icon of bluetooth but it cant find another device.
Go to settings-connectivity-bluetooth. Tap on the bluetooth symbol to turn it on.
Across the top you will see 3 menus. Tap on the middle menu button, press options then select new paired device.
Jul 28, 2010 | Nokia 5800 XpressMusic Smartphone
Blutooth bh-700
Hello, the manual will almost always tell you the default verification code. In this case it's the generic default 0000. If this dosn't work, look at the manual below under 'Pairing'.
Actually here's the manual: http://nds1.nokia.com/phones/files/main_page/Nokia_BH-700_UG_en.pdf
Nov 22, 2009 | Nokia Bluetooth Headset BH-700 for all...
INSTALL PROGRAMME THROUGH BLUTOOTH FOR Htc s710
yes. you must first register the device with your computer through the bluetooth manager. once they are linked you can transfer the install cab file by blutooth, but you must actually install the file from your device. please rate me if this helps. thanks and good luck!
Sep 18, 2009 | HTC P3470 Smartphone
Unable to recieve mms using bluetooth. Normal sms no problem.
apparently there is no such function to sent/recieve mms @ sms to/from another phone via bluetooth.. at least for this phone..
Jan 18, 2009 | Nokia 5300 Grey Cellular Phone
Bluetooth not powering
this problem results after unlocking the phone sometimes.
any way try to give it a soft reset press *#7370# and code is 12345.
if this is not working try to remove some blutooth devices from the list.
if this is not working aswell .
maybe its an electronic board issue maybe a the blutooth chip is faulty!!!
and that needs a repair .
plz
Aug 25, 2008 | Nokia 6270 Cellular Phone
Bluetooth headset Nokia BH-600
You just have to press your blutooth on/off button a bit longer for 15 to 20 sec, when the LED blinking stops (noted that the LED should be turn ON but not blinking), try to search the device again with your phone. By that time your blutooth headset should be recognized by your phone, then select and enter the code 0000.
Jan 28, 2008 | Nokia BH-600 Wireless Headset
Nokia 5300 Grey Cellular Phone Logo
56 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
