Question about Daewoo DTQ-27S5FC 27" TV
The sound on my TV goes out. It is less than a year old. After I turn the TV off and then back on, it work again for a while. Some channels are worse than others.
  • 2,113 Answers
It could be some bad soldering in your tuner  or some cold solder joints around your sound chip.
Posted on Nov 18, 2009
Testimonial: "I was not sure if it was my cable service or the TV. Thanks, that puppy is getting returned."
My 88 year old Mum's TV works fine on all channels except for Channel - 7 which is her favourite. We have tried reprogramming it, both Auto & Manuel many times. it flickers back for a moment, then goes...
Are you on cable or aerial?
If on aerial try turning the aerial a little one way or another.
We have to set ours for different channels we receive.
Feb 07, 2015 | Televison & Video
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
Try to re tune but it goes throught the motions but does not pick up any channels at all. Tried this many many times. all cabled up correctly. help required please. Its a TWFdigital STB501 Box (Digital...
You need to have a newer digital antena hooked up to it also if your tv is flat panel and its less than say 2 years old the digital tuner should be built in. I dont mean to sound dumb but if you are using a digital coverter box and thats what the antenna is hooked up to make sure your in the menu of the converter box. You can determine this by what channel the TV is on. If you hooked the Box to the coaxle then your TV should be on 3 or 4 if you used Composite(RCA) cables then it should be on aux. But once again I will say the antanna makes all the difference with digital. Old ones do not work. Please respond with more info if this doesnt help.
Dec 14, 2010 | Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Picture goes out right after turning on, have to
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Sep 24, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
My 46-inch Samsung LCD TV screen went black. Audio works.
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
Sep 13, 2009 | Televison & Video
Sound goes out on random cable channels..only on this tv
It might not be your TV it might be you Cable Provider. Get them to look at your cables in your home
Aug 25, 2009 | Sanyo DP19648 19 in. LCD TV
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
Great sound no picture
When I turn my tv on there is one certain channel that goes black after watching less than 5 minutes. this might be due to electronic tuner or loose contact in that particular section. 100% problem will be solved thanks
Sep 09, 2007 | Sanyo DS24205 24" TV
Toshiba CF36H50 turn
your problem is intermittent but from your complain it seems that your IF video circuit which is vry technical have your set checked by a technician.to resolve your problem the job will cost about $90.00
Feb 14, 2007 | Toshiba CF36H50 36" TV
Daewoo DTQ-27S5FC 27" TV Logo
85 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
