Question about Samsung DVD-V1000 DVD Player/VCR
Scrammbled screen in DVD mode
We moved the tv without disconnecting any of the cables into the DVD-V1000. Now when we push the DVD/TV button, we get a scrambled looking screen in the DVD mode, but in TV mode everything looks fine. I've checked the cables and the channel position. What might this be?
SOURCE: DVD V1000 samsung
RadioShack
Posted on Sep 01, 2007
  • 61 Answers
SOURCE: troble tuning in
If your recorder is hooked up after the cable box, then it can probably only receive channel 3...the set-top box does the switching, and sends everything to the TV (and recorder) on Ch. 3
Posted on Jan 27, 2008
Astrobyte
  • 110 Answers
SOURCE: 6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Posted on Feb 21, 2008
SOURCE: xbox 360 screen cut off on left side
Ok, I've had the same issue and I was able to fix my problem. I was getting cut off sides in HD mode on my playstation.
I entered the service menu by doing this:
Turn TV Off
Use remote and hit "Mute 1 8 2 Power" (not at the same time, but one after the other)
The TV will come on with the service menu. Enter the 1080i adjustment screen. Write down ALL the values in case you mess up. Adjust the values as necessary to fit your screen. It's sort of like adjusting a computer monitor's image for different resolutions.
Hit me if this helps... mlager at sysnosis dot com
Posted on May 03, 2008
ginko
  • 19396 Answers
SOURCE: VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Posted on Jul 26, 2008
I have a Neoniq 18.5" tv where the screen has gone blank. My beloved in a drowsy state pushed a few buttons to turn tv off. Is there a way to factory reset the tv without screen?
Hi maybe u put the TV into sleep mode UNPLUG THE POWER CORD FOR A FEW MINUTES & HOPE IT WILL LOSE ITS MEMORY:::::: hope this helps
Jan 31, 2016 | Televison & Video
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
How to install samsung dvd-v1000 dvd/vcr combo ? I lost instructions and need to know what cords to hook up where ?
if your using rca cables then plug the coresponding colors from the out on the dvd to the input on the tv
Dec 21, 2010 | Samsung DVD-V1000 DVD Player/VCR
Need a code for an emerson tv can't view dvds
I need more info about the remote! like Brand and model !
even without code! You should be able to put the remote into a search mode.
Here is some common procedure;
Put the Remote in search mode, while directing it to the turned on TV, push the power button repeatedly when the TV shuts down you should push the OK button immediately!
If you know the model and brand of the remote I might be able to help you more precisely
GL
Nov 24, 2009 | Televison & Video
Can only receive cable channels 2 through 13;
Turn the unit off, push the setup button 3 times. Press the seek left/right to switch between cable / antenna tuner modes. When cable is selected, press the channel up/down to switch between cable modes. When the unit turns back on, it will rescan for channels.
Aug 04, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Jun 13, 2009 | Sylvania 6420FB 20" TV
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
Closed caption
Closed caption wont turn off was solved by Bresnan tech. He told me the only way was to push the power button on my remote & then push the menu button right away & it would bring up a white screen & cc would be on it. I could't get it to work so I pushed the power button on my remote & the menu button on my motorola cable box & up came the screen & closed caption was on it. I disabled it & it took off the closed caption. Hope this helps
Dec 26, 2007 | Protron PLTV-32 Television
Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Sep 09, 2007 | Televison & Video
Connections
Hi If I'm understanding what you have written, the new DVD should hook up exactly the same way your old one did. You connect the red and white cable from the "Audio out" connectors on your new DVD to the "Audio In" connectors on the RF modulator, then connect the Svideo out on the DVD to the Svideo connector on the RF modulator. Then put your TV on channel 3 or 4 depending on what the switch on the modulator is set to, and all should work fine. I would advise you hook your old one back up, then if it works, simply unplug the cables from you old DVD and plug them into the proper jacks on the new one. This eliminates bad cables. If you then get sound, but no picture, the DVD may be set to progressive scan (check manual for procedure take it out of that mode),If you get nothing, then I suspect there is a problem with the new DVD player. The TV/VIDEO switch they mention, would be a switch on the TV or TV remote if you had a newer TV with RCA inputs.....You don't, so disregard that, it does not apply to your TV. You would not need the RF modulator if your TV had that switch. Good Luck!...These things can be a pain, I hope this helps!
Nov 28, 2006 | Daewoo DVG-9200N DVD Player
Samsung DVD-V1000 DVD Player/VCR Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
