Question about Panasonic Audio Players & Recorders
My Technics stereo system ...the display screen shows nothing
My Technics stereo system ...the receiver/amplifier suddenly quit. It has power but there is no display which I need to select CD, Tape deck, Radio etc .the brand is Technics Synthesizer AM/FM stereo receiver SA-GX100
  • cj barrett
    cj barrett Mar 17, 2014
    I Got exact same issue i only just bought this and am disapointed as this amplifier is a really good system, nothing at all is happening when i turn it on just the standby light goes out and thats it, i trie dclociking cd and listenning for any sound but nothing appears to be working :/
  • Anonymous May 28, 2017
    Same problem. Works fine, then I turn up the volume and with a couple of minutes the unit shut off. Wait a while and I can turn it back on. Weird!
  • 4,234 Answers
The question is, do you hear any sound? Is just the display off or is the entire unit shutdown? Can you tell?
These displays are known to develope poor solder connections at the power input and ground pins. If you can solder, open up the unit (unplugged of course) and examine the pins for the display. This will be on the PC board attached to the front panel. The pins at either end of a long line of pins will be the power and ground pins. Reasolder those pins, taking care not to short the pins together and try the unit once done. If that does not resolve the problem (assuming it is just a display problem), update this with as many details as you can about the behavior of the unit and we'll look further.
Dan
Posted on Nov 18, 2009
  • Craig Lindley Mar 18, 2012
    Hi there mine has done same, did u fix urs
Would I be able to connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
Yes, it is hooked up using the (cassette) tape inputs and outputs. Use the tape monitor switch on the receiver to switch the EQ in or out.
Feb 11, 2016 | Panasonic Technics Sa-dx930 A/v Stereo...
Technics 1080 pre amp volume control is not functioning correctly
Technics SE CA1080 Service Manual
there is a chip called an operational amplifier under a heat sink on the pcb,that fails when it get top volumed for two long theres regulators with heatsinks.
it is listed as,
Technics SE -CA1080 amplifier F61 fault,
May 13, 2015 | Technics Audio Players & Recorders
It doesn't want to work anymore!! There appears to be no power to the Disc Player, Cassette Deck or the Sound Processor? The Amplifier screen displays F61 Hope you can be of assistance Thank you
With my crystal ball I can see its a Technics 4 part Hifi micro system you have although the image is just too fuzzy for me to tell which model.!
Joking apart...Your power amp module has a blown channel. These are specific Technics modules and some for the 3/4/5 channel units are quite expensive UK £40-80 just for the module + fitting costs
No DIY fix I'm afraid
Sep 04, 2010 | Audio Players & Recorders
Describe your I have a technics sa ax910 turning
1 You may have a failing power supply regulating circuit in you amplifier and the fail safe circuit is trying to protect the rest of the circuit.
2. there may be a voltage overload at the primary side of the power supply circuit which in this case is causing it to shut down.
Jan 06, 2010 | Technics Audio Players & Recorders
Stereo does'nt stay on you turn it on and it just clicks n goes off technics dv290 system
problem with amplifier contact dealer,i have the samne problem with mine,its shows F61 on the diplay and when i check my user manual it states there is a problem with the amplifier
Dec 09, 2009 | Technics SC-DV290 System
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
SAAX7 Technics stereo receiver stops broadcasting after 20-30 min
Ron- The fan does not turn on when the receiver is first powered on, it will run when the amplifiers begin to run HOT, they are kinda controlled by a thermo switch, if the fan does not turn on usually the receiver will shut down and display a OVERLOAD message in the display panel. My advise is to keep the unit well ventailated with plenty of breathing space around the top vent closure, this will allow air flow when loud volume output is used. Also use the rated ohm speakers with the SA-AX7,
Jan 25, 2009 | Technics Audio Players & Recorders
341 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
