Question about Panasonic PT-51HX41 51" Rear Projection Television
Pt-51hx42f 3 red blinking lights come on when i try to turn on tv
Hey I noticed you really know what your talking about when it comes to fixing tv's! I have a problem myself, I have a pt-51hx42f and when i try to turn it on it just blinks the red power light 3 times, if I unplug it and turn it on, it seems like it is going to come on but then shuts off and gives the 3 red blinks. I know it is probably the stk392-110 and resistors because I already noticed they are burnt. I was wondering if you could help walk me through putting in the stk392-150's (went with those instead of stk392-110's).
    Scholar:
  • 86 Answers
Hi friend i appreciate the words of praise that you have given, but i only know what i have studied and still do study. i also learn more as i repair more. i wish i could give you an answer to the three blinks, but panasonic does not share its information as freely as sony. i will tell you this. i have replaced the convergence chips before. i have seen the burned resistors before. and i have seen the set come on and last from one day to one week. if you are going to get chips i would replace all of them and i would definitely not go cheap. the cheap burn out fast. sometimes you will luck up and get some good ones and sometimes you will not. when i have convergence problems i replace the board. (partstore.com) this way you eliminate changing cap, resistors and a host of other problems. the really good chips cost around $46 a piece, the board cost around $160. now since you do have them. cut the legs off close to the board and simply desolder them one at a time. then take your time and resolder the others. this has to be a skill of patience, but i know you will triumph. tell me also what was your tv doing before it went out completely. please rate my solution and thank you, you are very kind.
Posted on Nov 18, 2009
I have a 51" Panasonic Rear Projection HDTV,
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 12, 2013 | Televison & Video
I HAVE A PANISONIC HDTV1808I PROJECTION TV MODEL PT-51HX42F ITS A 2003 YEAR IT WAS WORKING THEN WENT TO TURN IT ON AND NOTHING ITS POWER RED LIGHT BLINKS 5 TIMES THEN PAUSES AND STARTS BLINKING THE SAME...
You need to replace the "Lamp" check Google Shopping for pricing. Enter your TV model # and add the word "Lamp" Make sure you get a Phillips or Panasonic lamp don't get a Chinese knockoff. They don't last!. Hopr this helps.
Jul 02, 2011 | Panasonic Televison & Video
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic lPT-51HX42F TV does not turn on but the red light in front is solid red.
The power module may need replacement, but there amy be other problems Panasonic has a code built in if the light blinks count the blinks and they will know the source.
Mar 24, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
Pioneer PT-51hx42f
hello. it sound like a power supply . problem to me.!!! check it.!!! "good luck"
Aug 02, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic model# PT-47WX547 is not working
how many times does the LED blink ? Thats a error code.
Jun 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Need Help big screen turns on thens goes off
The unit is going in to shutdown. Sounds like you have a short in the high voltage section.
Feb 18, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
262 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
