Question about Philips HTS3011/05 Theater System
The unit got stuck displaying DISK
The unit somehow got stuck and does not respond to any buttons directly or on the remote control. When plugged in it seems to go to red standby LED then automatically it shows PHILLIPS for a moment and then DISK. The Screen comes on at that same moment but only with the background image! It ramains with DISK on the display indefinitelly and does not try to load and does not allow ejecting the disk.
SOURCE: DVD load / eject problem
This is a solution to all those who have either a DVD which does not load and which cannot be ejected and also to those who have the system stuck in MP3 mode. The solution is the same for both problems. Unfortunately due to the design of the HTS6510 it’s not a simple job but if you are methodical and take your time then most people should be able to do it.
 I personally think the problem stems from dust building up on the laser. I noticed that the extraction fan at the back of the unit draws air, partly, in from the front slot and over the DVD and (Sony) laser.
Anyway I’ll talk you through what I did but please be aware that this is not a screw by screw, connector by connector account.
You’ll need a small torx screwdriver (the unit is put together almost exclusively with a single torx screw size),  a very small Phillips screwdriver and a pair of snipe nosed pliers. Also a couple of small bowls to hold the screws in will be a good idea.
Firstly make sure the unit is disconnected from the mains. Then begin by undoing  the four torx screws at the back of the unit which are holding the cover on. Then remove the silver plastic side sections by sliding them towards the back of the unit. Under these you’ll see two more torx screws to be removed on each side. Remove these and you can then remove the top cover.
Have a look at the first attached picture. You should see the same thing with the lid off the box. I’ve labelled all of the assemblies up. There are four circuit boards which are arranged two on the top and two underneath these. You will be removing the top two (Audio amplifier board and the power supply board).
The aim of the game is to move the front section (the bit with all the control buttons on) away from the main section so that you can get access the to the DVD housing (this is the player unit where your DVD is housed). The front section is attached to the main section by four plastic clips (the plastic barb to metal slot type). Two are accessed from the base of the unit and more on each side. Don’t unclip these yet because the circuit boards are attached by ribbon cables which attach to the front of the unit . It is these ribbon cables which must be disconnected before the front can be unclipped and access can be got to the DVD unit. There are also a couple of bonding leads which attach the front of the unit to the ain chassis. These have small spade (push on) connectors and are very simple to remove.
You don’t need to disconnect all of the ribbon cables – just enough for you to be able to swing the front of the player out of the way.  Make sure you mark any connectors which you disconnect in some way so you remember where they connect to when you re-assemble the unit. I used a permanent marker to put a series of dots on the ribbon end of the connector and board end of the connector. (i.e. one dot on each denotes a pair, the next pair has two dots etc etc.)
Some of the leads which you will need to disconnect are attached to the two processor  boards which sit below the two uppermost circuit boards. Gain access to these by removing the four screws (one on each corner) holding the power supply board onto its mounting (there is also a nylon support in the middle of the board – squeeze it with a small pair of pliers to release the board).
Next remove the black plastic insulator sheet below the board. With this board removed, the metal shelf which the Audio amplifier board is attached to can now be removed. Note that some of the screws on the external back of the unit will also need to be removed before you can do this. You don’t need to take the audio amplifier board off the shelf – just remove the shelf and audio  amplifier board together.
You should now have an assembly which looks like my second picture. As with the top two boards unplug the connectors on the boards to allow the front section of the dvd player to be moved away from the main part of the system. Again don’t forget to mark the connectors so you know how to re-connect them.
If you have got this far you are doing very well!  I then undid the four screws holding the dvd housing and unshipped the entire housing, but with hindsight this wasn’t necessary. There are four Phillips screws holding the top cover of the DVD housing on. Remove these with your Phillips screwdriver and lift off the lid.
You can now remove the DVD / CD. At the same time carefully remove any dust which has accumulated in the DVD housing. Take care not to damage the delicate lens or its assembly. I used a dry cotton bud but a blast of dry air or a lens cleaning brush would be an even better choice.
Once the dust is removed refit the cover the DVD housing and assembly is basically a reversal of the dismantling. Once its all back together switch on and they system will be back to normal. If it doesn’t switch on – open it up and recheck your connectors – most likely one of them isn’t properly engaged.
Posted on Nov 02, 2008
SOURCE: My dvd model is philips dvp 3005 and it is in standby mode
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
ramon49
  • 111 Answers
SOURCE: phillips stereo won't power up
Leave relay alone! check those big fat transistors , usually shorted...
Posted on Mar 07, 2009
SOURCE: 3370 H player is 'blocked' cannot eject disk
en la parte inferior del aparato hay una ranura alargada. hay que mover el switc e inmediatamente se desbloquea.
araceli
Posted on Mar 28, 2009
SOURCE: Phillips 42FD9954 plasma will not turn ON
I have a Phillips 42FD9954/17S and every time I try to turn it on I also get the power red light blinking and sometimes it will try to turn on with a bunch of clicking noises and it will be green for a while then turn red. What I do and its very weird but works, put a blow dryer on hot and blow it under the tv on the side of the power button for about 10 minutes and it will turn on. I took it apart and there is a heat sink that if i put the blow dryer directly onto it on heat it turns on in less than a minute. Can someone tell me how I can fix this heat sink? I cant take it off. I want to put some thermal compound to see if that works. Give it a try I promise it will work. The Red Light has to be on put the heat on it and then press the power button, if you hear it clicking and green then back to red you are almost there. Keep putting heat on it and it will turn on.
Posted on Mar 31, 2009
Receiver freezes and does not communicate with remote, stays powered on though
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Apr 02, 2017 | Televison & Video
Dvd stuck in Samsung bluray
Have you tried pulling the plug for a minute? Also try the eject button directly from standby.
Nov 26, 2013 | Samsung BD-F5100 - Blu-ray disc player
I have an split-type aircon (brand: Fukitsu) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift indoor unit cover and remove DC wire from display sensor. After 3 minutes again plug it and close the door. Now you try with your remote. If still problem, check your remote through cell phone camera by pressing any button in remote. If ultra light is visible thr' camera, remote is o.k. If remote is o.k, repair/replace PCB. Thanks.
Feb 09, 2011 | Heating & Cooling
When I turn on my unit the display is stuck with REMOTE ON
Move the remote to another room to test. It is possible a button on the remote is stuck on.
Beyond that , it probably needs to go in for service.
May 16, 2010 | Sony CDP-CX400 400-Disc CD Changer
My logitech 550 is not responding. It has worked
Hi. That message means that there is a button that is stuck down on the remote.
1. Take out the battery, push in and massage each button to ensure it is not stuck down.
2. Put the battery back in, update the firmware,
3. Update the remote.
That should get the remote working again. :)
Oct 31, 2009 | Logitech Harmony 550 Remote Advanced...
Unit does not respond to remote control
I had this same problem with the Onkyo TX-SR706 this evening, and finally found the solution in the "Controlling Other Components" section of the manual: Resetting the remote control did the trick. (P.S. This problem started after I spent many hours today trying to get my new Acer laptop equipped with a Hauppauge TV tuner stick to correctly display its image on my Samsung HDTV, with sound. I tried connecting the laptop via HDMI first to the Onkyo receiver and then directly to the TV, neither of which worked as it should. I assume that somehow, in all those hours of much plugging and unplugging and fiddling around, I screwed up the remote sensor -- thank goodness I eventually found the "Resetting the Remote Controller" solution a little while ago -- I was approaching the point of ripping everything apart and throwing it out the window!)
Jul 06, 2009 | Onkyo TX-DS575 Receiver
Universal remote locked out TV
I was able to get back to using the TV after several frustrating tries at finding the right combination of searches and pressing buttons. The function I was able access was not a function I could get to with the remote suppilied with the TV. And once stuck in this mode nothing would clear it Turns out that the power button gave me channel 8 and the #1 button gave me this display calibration? function. Obviously not using the right code. Never the less all is well with the TV and I got my VCR working with the $2.99 remote and I will attempt the other units TV and Magnasonic DVD later when I have regained my composure.
Nov 29, 2008 | Universal Televison & Video
A disk is stuck in the tray of my sony DVP-NS305 player. The disk tray will not respond to either the hand piece or the button on the player itself. The word "Locked" comes up on the display. How...
Unplug power cord, and whenb you plug power back and restart the DVD, keep pressing repeatedly the eject button on the unit.
Do this a couple of times.
If it does not work you will need to take apart the unit to take out the disk. In this case consider calling a qualified technician if you are not sure about how to do it.
Oct 04, 2008 | Televison & Video
No Disk
When I try to play a DVD, operation seems normal, the unit makes a slight noise like the disk is rotating and "Loading" is displayed. Then after about 30 seconds the message "No Disk" is displayed. Then just the Polaroid screen is displayed. I have lost the remote control but surely the unit will play using the front panel buttons. One thing, only the remote is named as having a Setup Button in the manual but the unit has no such button.
Apr 12, 2008 | Polaroid PDV-0813A
Philips HTS3011/05 Theater System Logo
52 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
