Question about HP Color LaserJet 2600n Printer
HP Laser Jet 1600
Just curious, when printing only black text on a page, why
would it use the pink cartridge also?
Is there a setting i need to check, or is this supposed to happen?
  • 4,402 Answers
In the Windows environment, the Automatic and Manual color options are on the Color tab in the printer driver. choose manual and print in grayscale
Posted on Jan 10, 2008
  • 233 Answers
It should not, when you say pink you mean Magenta right?
sounds like it needs some cleaning, pull out everything you can pull out from the printer, and carefully clean any tone you see inside with a dry cloth, also clean the cartridges themselves.
print a few pages for any remaining toner to get phased/cleaned out on the print outs and see what happens
thanks for rating
Hp laser jet 1600 wont print after refilling black carterage
Not sure if the 1600 has the same printer cartridge, but I have a 4620, and had the same thing occur with the black ink. After a few hours on the phone with HP and them sending me a replacement printer that also wouldn't print, I found that there is a "vent" on the printer cartridges that if clogged, will cause that color not to print. The vent is on the top of the cartridge, facing up when installed into the printer. The vent looks like a "T". Unfortunately, the packaging that HP uses on these cartridges sometimes causes glue to clogged the vent. Take a sharp nail or straight pin, and clean out the vent. Hope this is successful for you.
Aug 02, 2014 | HP LaserJet Office Equipment & Supplies
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
I hope it helps you solve your problem.
Feb 15, 2011 | HP LaserJet 3030 All-In-One Printer
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
HP printers - remove and check cartridge. (Use it or lose it)
There is no solution for HP Printers being used very lightly - meaning "not for months" etc.
As a result, if you are stuck in this predicament - an HP inkjet, that you only need every few months - I instead suggest you set a calendar entry for once a week or more and run a test page.
The printer will "hopefully" not dry out by being periodically used - and the ink "wasted" will result in a LONGER cartridge life than if you had to throw out a cartridge.
There is also a time period, or sensing of the cartridge, that results in a wasteful cleaning cycle in which it pumps ink "down the drain", and I'd like to know how often to test print to avoid that.
My solution to my most recent problem was to "give up" and throw a new (black) cartridge on it and take the barely-used one out.
Jul 07, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
Smudge mark along entire right side of every page.
HP 1600 is quite a decent little printer, so you shouldn't be dissapointed - if it's working properly, which clearly it's not in this case.
It seems that you have 2 problems here.
Firstly it shouldn't click loudly, so you need to be talking to whoever you bought the printer from.
The smudging - is probably a dirty fuser.
There are laser printer cleaning sheets, that will work quite well, but ideally it needs a little bit of dismantling to get at the fuser to clean the two fuser rollers.
I've seen lots of these with dirty fusers, and a clean with IPA does the trick.
Jan 03, 2009 | HP LaserJet 1600 Printer
My HP Laser Jet (color) 1600 is printing color on pages with no color!!
the wastage part of ur pink toner is full a is dropping the powder on paper.get it cleaned to continue good printing.wish u success
Jun 04, 2008 | HP LaserJet 1600 Printer
HP Color LaserJet 2600n Printer Logo
206 people viewed this question
Ben Johnson
