Question about HP Pavilion dv9000z Notebook
I only get all blue light on, but no video when I turn on HP Pavilion dv9700 computer. I tried to remove battery and memory, hold the power for 60 seconds and put everything back, still no luck. When I removed all memories, I got 4 beeps but still no video. Any suggestions?
    Scholar:
  • 101 Answers
Does the computer seem to be starting all the way to windows? You can test this by playing a CD after it has fully started. If the CD won't play then it is probably not passing the POST (power on self test). If the CD palys it may just be your LCD inverter is bad. In that case you should be able to see the logo but very faintly, right at start up.
Let me know what happens.
Posted on Nov 18, 2009
My HP pavilion dv6700 won't power on. I have a blue light at the power cord but can't power up.
disconnect the power adapter 2) disconnect the battery too 3) Press the power and hold the switch button power by 60 seconds. Then proceed in reverse and Power again and can be fix it.Of course if the problem remain test the memory from your pressing the key f2 or f9 depending of your modell in the reboot and go to the test memory.
God bless you
Mar 22, 2013 | HP Pavilion dv6000z Notebook
HP Pavillion dv9700 does not power on
It would seem that the power button is faulty, usually, this is because one or more of the four solder connections by which the switch is attached to the printed circuit has become detached, sometimes caused by pressing it too hard. Rectifying this is quite an intricate job requiring a lot of disassembly and skilled soldering. If you are in any doubt take it to a professional.
Apr 07, 2017 | Computers & Internet
My HP laptop (pavilion dv9700) will not start up. It was working fine then suddenly shut off while the cord was plugged in. The blue ring still lights up where you plug in the power chord, but nothing else...
Try the following:
  1. Unplug the power cord from the laptop.
  2. Remove the battery.
  3. Press and hold the power button for 10 seconds.
  4. Re-insert the battery.
  5. Plug in the power cord.
  6. Try turning on the computer.
Jun 07, 2011 | HP Pavilion dv9000z Notebook
I had graphics problem,after resolved by an exprt the power problem starts within a day. Now it is not starting. Do i have to change motherboard?
not yet,,
remove the graphics card, remove the pc memory remove the battery from the board, press and hold the power button for 12 seconds release put back, battery and memory and graphics card turn on, load default values and contine, should be fine.
Apr 04, 2011 | HEWLETT-PACKARD Hewlett Packard 459566-001...
My hp dv 8000 Pavillion laptop will turn on and then it immediatly shuts down after 5 seconds or so
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
and if this doesn't help
then try to take out the ram or memory chip from the computer and place it back.
Jan 12, 2010 | HP Pavilion dv8000 Notebook
Problems with HP HP Pavilion dv5-1159se 15.4
Oct 29, 2009 | HP Pavilion dv5-1159se Laptop
Laptop won't turn on, no lights - nothing!
Oct 26, 2009 | HP Pavilion zd8000 Notebook
I have an HP Pavilion 9000 that was working just fine. We powered it down for the day and when we went to start it up the next day it would not start. Blue light is lit where power supply plugs into...
That a nice computer you have there. Based on your description, my guess is you have a bad power supply.
About a $300 fix if you send back to HP. Which is what I had to do a while back.
Oct 20, 2009 | Compaq Laptop Keyboard for HP Pavilion...
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
TRY HOLDING DOWN F10, F12 BEFORE YOU TURN ON THE SYSTEM, WE ARE TRYING TO GET IN THE SAFE MODE TO CONTINUE IN WINDOWS TROUBLE SHOOTING GUIDE, REMOVER THE BATTERIES AND UNPLUG THE SYSTEM TO FORCE IT TO TURN ON IN SAFE MODE THAN SELECT THE ONE MOST LIKELY SOUND WHICH ONE WILL DO THE BEST JOB FOR THE BANG.
Feb 13, 2009 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
128 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
