Question about LG DLG5988 Gas Dryer
Lg electic dryer
Dryer heats and seems to be blowing ok outside of house, but
still takes to long to dry. It doesn't get dry on sensor mode.
Larry
  • 489 Answers
Your vent to the outside is restricted and needs to be cleaned out.  To check this, remove the vent line behind the dryer and run a load.  If the clothes come out dry in a normal time, the problem is in your vent.
Posted on Apr 28, 2008
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dryer works fine except it does not seem to heat properly. Wondering how the element is installed and where I could find replacement heating element.
I would need a model number to look up your heating element.
I can tell you that chances are if the dryer heats, but just takes to long to get things dry the heating element is probably ok.
Poor air flow is what causes dryer to take longer then normal to dry.
You will want to check your vent for restrictions such as kinks or lint build up. Don't forget to check the outside hood as it has a flapper or even a screen that can catch lint.
If your vent is ok then you need to take the dryer apart and check for lint build up around the blower housing and fan.
Aug 02, 2011 | Dryers
Why doesn't my LG Dryer not dry clothes well?
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Nov 26, 2009 | LG DLE2514 Electric Dryer
Gas dryer does not seem to heat up takes a long time to dry clothes.
Sep 12, 2009 | Dryers
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 29, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Dryer warm but not hot, long dry times
some times there are multiple heating elements in there and if one is out it does not get as hot. another simpler place to start would be to make sure your line is clear of debries all the way from dryer to out doors. this is a good idea any way since lint build up can cause the occasional house fire.
Jan 23, 2009 | Dryers
Dryer doesnt heat up enough to dry clothes
sound like the vent duct going thru the wall to outside is stopped up / check your duct and outside dryer flap to make sure the air is open / if blocked it will take 2-3 times as long to dry and make it seem like the dryer isn't drying / larry
Dec 02, 2008 | Kenmore 62602 Electric Dryer
Whirpool Dryer......
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Jan 21, 2008 | Whirlpool GGQ8831L Gas Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
LG DLG5988 Gas Dryer Logo
85 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
