Not feeding paper all the way
When we receive a fax it not feeding all the way out. Can the rollers be cleaned or is it just worn out? Canon faxphone L80
  • nelastar Jul 11, 2008
    When we try to send out 10 pages of fax, not all pages go through.
Never use Alcohol on rubber feed rollers. I am not sure what the fix is for your problem, but if you use alcohol on your feed rollers you will have another problem. Alcohol removes moisture from rubber, over time the rollers harden and will need to be replaced. DO NOT USE ALCOHOL ON RUBBER.
Posted on Jun 16, 2008
  • 1,003 Answers
YES THEY CAN BE CLEANED first before replacing anything
Use microfiber towel moistened with rubbing alcohol to clean feed rollers
Posted on Jan 13, 2008
Fax wont print,keeps saying check paper size,ive used same paper size for years
the problem is in flaper of registration sensor, it got worn out.
Replace it, and do the preventive maintenence routine ( check/clean/replace rollers, clutch,... )
Jun 23, 2010 | Canon FAXPHONE L80 Laser
Will not pick up paper when receiving Fax or asked to Copy . Transmits fine and receives into memory but cannot get a paper copy of received transmissions.
Remove cover for paper, and you will be able to see the two small rollers on plastic axis. Clean them. ( each side, but when you turn them manually, put it back in first position )
May 26, 2010 | Canon FAXPHONE B640 Plain Paper Bubblejet
Paper no longer picks up and feeds
If u look in at the back there is a big big Grey roller the a can clean and in the front there is a big Black roller that u can clean!Good Luck!
Mar 17, 2010 | Canon FAXPHONE L80 Laser
My fax machine only feeds paper to one side when I'm sending a fax. I cleaned the roller with WD-40 but it still only rolls to the right.
Most of the times there is a dockument stop arm thac6cfff.jpgat broke that cause the paper just to feed one side.What you can do is to remove this arm.I have pointed with a sckrew driver this part.After removing this document stop you will be able to use the fax while ordering a new part.
Aug 27, 2009 | Canon FAXPHONE L80 Laser
Paper sticking together when receiving a fax
There is a separation pad under the feed roller,that pad needs to be cleaned or replaced.If you open the fax and remove the cartridge,inside at the back were the cartidge was you will find a roller,cleen that roller.Under the roller there is a strip of rubber-the separation pad.Take a ruller cover it with a cloth and use it to clean the sep assembly under the roller.If the problem pressist the sepparation needs to be replaced.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
When receiving a fax, it seems that several pages of paper always
you mean you're getting 1 or 2 extra sheets when machine is printing faxes? Feed roller and separation pad that pull paper from the tray are will help in the short term.
Canon faxphone L170 won't copy
if you look at the top piece of paper in the cassette is there a smug mark or wrinkle in the paper. you my just need to clean the feed roller. ( black or gray roller ) . I'm not sher on this model if it is a rear paper feed or a cassette from under if it is a back feed one look in side the paper shoot of any fourn object is in there. Hope for the best.
Feb 02, 2009 | Canon FAXPHONE L80 Laser
Canon L170 will not feed paper in for faxes or copies.
as the rollers move with the help of the side gears .which r made up of plastic and that gears r worn out or got cracked as due to this it pulls the paper but the gears are cracked so it does not pulls the paper further and it hangs in to resove this the gears needs to be cleaned and checked if the problem not solved the gears neeeds to be replaced. thanks.
Jan 27, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Canon b640 problem
By cleaning the feed rollers you the fax will feed beter.Remove the dockfeeder and the paper will find the feed rollers in the bottom of the paper tray.Take a cloth and a stong soap selution and clean the 2 feed rubbers.
Jan 06, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Paper feed
try to replace the paper with another from different manufacturer
May 18, 2008 | Canon FAXPHONE L80 Laser
568 people viewed this question
