Question about Shure PGX14/20 Professional Headset
I loose signal with 2ft of my shure pgx14 headset
  • 566 Answers
I`ve repaired a few of and its almost allways the same problem. The antenna on the transmitter (the one attached to you belt) breaks off inside at the base. If you`re handy with a soldering iron you can take the back cover off and remove the antenna for replacement or in some case cut off the broken part and re-solder the rest but it might affect the range.
And by the way this is for the flexible antenna. Hope this help. good luck
Posted on Nov 18, 2009
Sennheiser ew g2 bodypack with shure u2 receiver compatibility: When I tune the frequencies similar to each other, the U 2 gets an RF-Signal, but it doesn`t receive any audio-signal, when i talk into...
Sorry, that will not work. Typically, it is not possible to use one manufacturers transmitter with another manufacturers receiver. The two manufacturers use different tone-key squelch, different noise reduction, and different companding schemes.
Aug 09, 2013 | Shure U2 / 87 With SM-87 Professional...
Shure wireless guitar pack won't turn on
First, replace the battery. If that does not resolve the problem, call Shure Repairs at 800-516-2525.
Jun 10, 2012 | Shure PGX14 Guitar Wireless System (UHF)...
I recently purchased my PGX14/PG30 Shure microphone about 1 month ago. I went to use it at a performance last night, but it would not sync to the transmitter. I had new batteries in it and I repeatedly...
1) Make certain the bodypack is turned on. The LED on the bodypack should be green.
2) Make certain the battery door is OPEN.
3) Point the batteries toward the receiver (6 to 8 inches away).
4) Press and release the Sync button on the receiver.
The following video also steps you through the process:
Jan 09, 2011 | Shure PG 30 Headset
Should I run my guitar through the High z aux. Or the low z balanced for best results ?
I assume you are wanting to connect the output of the receiver into the input of your guitar amp. Use the 1/4" output on the receiver to the 1/4" input on your guitar amp.
Dec 23, 2010 | Shure PGX14 Guitar Wireless System (UHF)...
No audio out of the left side headset Shure SCL4
There's not much to repair on these. I'd suggest sending them to Shure. They will replace them for a nominal fee. www.shure.com/service
Jul 13, 2010 | Shure i4c Headset
What jack is compatible to laptop using shure
You have to connect the unbalanced output (the 6.3mm jack) to the laptop's line in (or mic with setting the rec level at very low settings) 3.5mm jack. In details the wiring should be as follows:
6,3mm jack shield to 3,5mm jack shield
6,3mm jack ring to 3,5mm jack shield
6,3mm jack tip to 3,5mm jack tip and ring
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 12, 2010 | Shure PGX14 Wireless Guitar/Bass System...
PLEASE HELP: Fuzzy when too far away from phone (2ft)
Check your maual to see how far the distance is on the headset. Also, things like alot of electronics can weaken your sync signal.
Jun 15, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Gjk
Try going to the doctor. It looks like you are having epileptic seizures.
Jan 21, 2009 | Shure PGX14 Guitar Wireless System (UHF)...
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Headset stops working
There are many, many things that could cause this symptom. You might need to send it to Shure for repairs. I'd suggest calling Shure Support at 847-600-8440 for assistance in troubleshooting.
Feb 22, 2008 | Shure PGX14/20 Professional Headset
Shure PGX14/20 Professional Headset Logo
70 people viewed this question
Top Shure Radio Communications Experts
eradiostore
eradiostore
Are you a Shure Radio Communication Expert? Answer questions, earn points and help others
