If I am using unsecured open wifi network to connect, if there any way maybe command prompt that I can see all other users along w their computer name and ip addresses that are also connected to the same wifi network I am. I cannot log into router so that is not an option. ipconfig/all does not work net view gives me other options, not sure how to use it this is for advanced level wifi experts thank you
  • 2 more comments
  • JOE Nov 18, 2009
    did not read my post; I want to find out all users who are connected to same access pt as me
    this is easily done if you can login to router
    view dhcp clients eg.
    however cannot login wirelessly or hardwire as I explained, not an option
    the rep explained if my ip was(eg 192.168.178
    then I would ping 192.168.179, 177, 180 etc
    This is tedious and firewalls block this, also this will not give computer name currently online w his ip address to that computer
    the best way was w net view or net views cmd prmpt, however options after using this
    is hard to understand
    ipconfig/all for some reason gives me error
    net view says server name not currently avail
    please research this further, thank you
  • JOE Nov 18, 2009
    this gives me 3 columns local foreign and state
    I see my ip address in there along w 4 numbers at the end
    I tried this on a network that I was Able to login to active dhcp clients, only showed myself and 1 xxowner
    why is this showing plenty of "foreign" addresses unusual ip addresses that are not even similar to mine?
    This is best solution so far, but please explain the 3 columns and what are all the other ip addresses that are 'foreign'?
    Please explain, thank you.
  • JOE Nov 18, 2009
    I used your method netstat n , I am coming up w 3 columns, local address foreign address and state
    I see my ip under local address along w 4 more digits eg: 192.168.1.15:1556, 192.168.1.15: 1634 etc
    What are these last 4 digits after my ip address separated by colon?
    under foreign I see 127.0.0 etc w colon etc
    then 3 ip addresses very much different than my ip address, all under state say established
    2 of them come up for isp's, one for a security intrusion system
    I don't see any rt now similar to my ip address format, so would mean at this moment there are no other clients connected to this acc pt besides myself?
    You response please
    Thank you.
  • JOE Nov 21, 2009
    Thank you, was the best solution, shows comp. name, ip address,mac address etc.
    Thanks very much
  • 748 Answers
I would suggest using a network scanner, which will allow you to discover all the machines on your network along with any information they allow to be seen about them (machine names, IP addresses, shared resources etc.)
The one I use is Softpedia Network Scanner, which is quite comprehensive, and free. Please be prepared to wait some time for the network device discovery tasks to finish - it may even seem that the application freezes - but be patient.
It will suggest the IP address range based on your network settings automatically, so all you need to do is start the default scan.
Here's the link:
http://www.softperfect.com/products/networkscanner/
Have fun :)
Posted on Nov 18, 2009
    President:
  • 2,185 Answers
Hello there Fixit2009,
From the command prompt, type:
arp -a >iplist.txt
This command this will create a text file named "iplist.txt". It will be saved in the directory where you initiated the command.
Next, close your command prompt and open the iplist.txt file thru a notepad or wordpad. It will list the ip addresses connected to the network.
Please let me know if this helps. Good luck!
  • 4,281 Answers
GO to start menu then type in run "cmd" Then type in command prompt "netstat -n"
So you can view all session of connected users.
Check local ip address if it is in your ip range then it is connectred to yourt network.
    Scholar:
  • 159 Answers
Type in the following in the command line:
ping -a XXX.XXX.XXX.XXX
and press enter. The XXX.XXX.XXX.XXX represents the IP address. The -a resolves the host name. You will see the host name, or computer name, as the first line after you press enter.Here's how to determine the IP addresses.
Start by doing an IPCONFIG from the command line. Take a look at your IP Address. The first 3 octets are going to stay the same. Change the last octet. For example:
If your IP Address is 192.168.1.16, ping 192.168.1.2, 192.168.1.3, etc. If you do not get a reply from that IP Address, then the computer is not currently online.
I have a surface tablet unable to connect to wi fi
Solution 1 - Reset TCP/IP stack
To reset your TCP/IP stack, do the following:
  1. Right-click on the Start Menu button and open Command Prompt (Admin)
  2. Type the following command and press Enter: netsh int ip reset
  3. Reboot your PC and check if you're able to connect to WiFi network. If you can, you're good to go, but if not, type the following commands in the elevated Command Prompt and press Enter after each one:
  • netsh int tcp set heuristics disabled
  • netsh int tcp set global autotuninglevel=disabled
  • netsh int tcp set global rss=enabled
  • ipconfig /flushdns
Solution 2 - Re-configure WiFi Adapter
Maybe reconfiguring your WiFI adapter will solve the problem. To do so, follow next steps:
  1. Go to Search, type device manager and open Device Manager
  2. Right-click on your wireless adapter and go to Properties
  3. Go to Power Management tab, uncheck Allow the computer to turn off this device to save power and click OK
  4. Modify the default power plan, and switch it from high energy savings to low
Jun 30, 2014 | HP Compaq nc6000 Notebook
Tip
How to your link to an iPod Touch WiFi
<p>It has all the power of your iPod touch by connecting your device to a WiFi network Connect your iPod Touch WiFi can pull in email, get directions with the Maps application and search the iTunes Store. To connect to a wireless network, obtaining information from the network administrator about the connection, including the name of the signal as it is hidden, the authentication type and password required for use. After obtaining this information, you can configure the WiFi devices are made in minutes. <br /> <p><br /> <p>1. Tap the Settings application on your iPod touch. <br /> <p><br /> <p>2. Tap "Wi-Fi." <br /> <p><br /> <p>3. Tap the slider to the right of the Wi-Fi says "ON". <br /> <p><br /> <p>4. Tap the WiFi signal you want to connect in "Choose a network." If you get an unsecured network, no password and you are automatically connected to the wireless network. If you are prompted for a password, enter it when prompted and tap "Join". You are now connected to the wireless network. <br /> <p><br /> <p>5. Press the "Home" button just below the touchscreen device to return to return to the home screen. <br />
on Aug 05, 2011 | Computers & Internet
Where do i find my ssid on my router
Out of the box your SSID should be linksys
You can find your ssid and change it by logging into the router interface, and checking the wifi settings. You will have to be connected with an Ethernet cable or use a computer that is already connected to your wifi network.
Start by getting the ip address of the router:
1.Press the "windows"+"R" keys (this will open the "Run" dialog box)
2.Enter "CMD" in the Run window, and press ok
3.In the Command Prompt window enter the following command "ipconfig" and press enter
4. locate the Ethernet adapter or local area connection if using an Ethernet cable. If you are using a wifi connection, you want to locate the wireless Ethernet connection.
5.Under one of those headings you want to locate the "Default Gateway" address. It will most likely be similar to one of the following: 192.168.1.1 or 10.0.0.1
6.Open a web browser and enter the address you found under the default gateway.
7.You will get a login page for your router. Usually the login formation is as follows:
admin/admin
admin/password
admin/leave the password blank
9.Once you have logged in you want to locate the wifi/wireless menu on the page.
10.Here you will find the SSID of your wifi network
Nov 28, 2013 | Linksys Wireless-G WRT54G Router
My Kodak printer ESP5250 is not printing The Wi Fi light flashes every 15 seconds.It has 100%conectivity. any ideas please?
make sure the WIFI printer is connected to the same network were your laptop or another device connected too.. try pinging the WIFI IP address by using the laptop under command prompt if you get a reply means the Printer is connected to your Home network and maybe re-=install the software of the printer to your laptop.. and follow the steps by steps... hope this help
Oct 15, 2013 | Kodak Cameras
No network coverage
Set IP Address Configuration
Click the "Start" button and select the "Control Panel" from the right column to open it.
Select the "Network and Internet" section of the Control Panel.
Click "Network Connections" if using Windows XP to view the available network icons.
Or, click "Network and Sharing Center" if using Windows 7 or Vista and select "Change adapter settings."
Right-click your network connection icon which displays either the yellow triangle or red "x" indicating limited or no connectivity.
Select "Properties."
Click on "TCP/IP" to select and highlight it. Click "Properties."
Select both the "Obtain IP address automatically" and "Obtain DNS server address automatically" radio buttons.
Click "OK" and then "Close" in the Network Connection Properties box. Close the Control Panel.
Manually Renew IP Address
Click the "Start" button and choose "Run" from the list.
Type "cmd" in the "Run" box and press "Enter" to open the Windows Command Prompt.
Type "ipconfig /release" in the Windows Command Prompt and press "Enter."
This releases the current IP address of your computer.
Type "ipconfig /renew" and press "Enter" to obtain a fresh IP address.
When renewing your IP address, Windows automatically attempts to connect to the network.
Powercycle Router and Modem
Turn off your computer.
Unplug both the Internet modem and wireless router's power adapter from the electrical outlet. Wait for two minutes.
Plug the Internet modem into the electrical outlet first. Wait for connectivity lights to appear.
Plug the wireless router's power adapter back into the electrical outlet.
Confirm that lights appear on the router indicating that it has established a connection to the modem.
Turn on your computer.
Open "Network Connections" if your computer does not connect automatically to the network.
Select a network from the list, input the network password if one exists and click "Connect."
Open your Internet browser to test the connection.
Update Network Interface Card (NIC) Drivers
Click the "Start" button. Right-click "My Computer" or "Computer" from the Start Menu. Select "Manage." Click "Yes" if a user account control message appears.
Click on "Device Manager" from the list of System Tools.
Find the "Network adapters" listing and click the "arrow" or "plus" symbol to expand it.
Right-click your computer's network adapter from the list and select "Properties."
Click the "Driver" tab and select "Update Driver."
Follow the on-screen prompts to allow Windows to find and install the drivers automatically. Restart the computer when the process is finished and attempt to re-connect to the network.
Reset Internet Protocol (TCP/IP)
Click the "Start" button and select "Run."
Type "cmd" and press "Enter" to open the Command Prompt.
Type the following line into the Command Prompt and press "Enter":
netsh int ip reset resetlog.txt
Close the Command Prompt. Issuing this command tells Windows to remove and then re-install the two registry keys used by the Internet Protocol (TCP/IP) component of Windows.
Restart the computer.
Attempt to connect to the network if a connection is not established automatically.
Sep 06, 2013 | Computers & Internet
Limited or no connectivity to wifi.
Do the other machines on the network connect to the internet?
If so, you know its a problem with your wifi settings. Try opening a command window: start>all programs>accessories>command prompt. In this window type: ipconfig /release and press return. Then type: ipconfig /renew and return. This will assign a new ip address to your machine. If it is a problem with the network you will need to reset the modem/router and reconfigure it with your ISP details.
Mar 28, 2012 | Toshiba Satellite A35-S1592 Notebook
We have a desktop computer and an ASDL line to it (ZXDSL 852 router). We would like to make it possible to use 1 or 2 laptops at the same time. What do we need to do to make that possible? I think we...
no need to buy a livebox or router here is the key to make your laptop become and access point
Install the ZXDSL modem to the laptop
Follow these steps very carefully now
Step 1 :
Goto Network and Sharing Center in Control Panel and then Navigate to Change Adapter Settings Over there.
Step 2 :
Select the Adapter on which you are currently using Internet on your netbook or laptop, Right Click on it and goto Properties.
Step 3 :
In Properties goto Sharing Tab and Select Allow Other Network Users to Connect through this Computers Internet Connection.
Step 4 :
In Home Network Connection select the Virtual Wi-Fi Adapter and press OK.
Step 5 :
Now Open Command Prompt (cmd.exe) on your PC with Administrative Rights.
Step 6 :
Type the following Command, just remember to change the SSID and Key (Password) as per your Requirements.
netsh wlan set hostednetwork mode=allow ssid=Your Network Name key=Your Password
Step 7 :
The above command will configure your virtual wireless adapter, and configure it.
Step 8 :
Now in the command prompt with Administrative Rights type the Following to Activate and use your Virtual Wi-Fi Hotspot Access Point.
netsh wlan start hostednetwork
Step 9 :
Now you can use the Wireless Wi-Fi Hotspot Access Point to share the net and use it on your other wi-fi devices. Also, you can Stop this network by replacing 'Star' to 'Stop' in the command in Step No. 8 and using it with administrative rights.
Step 10 :
All done, if you know to use command prompt and you play around a bit, you can see your network status and also can play around and experiment it with the 'netsh' Command.
This is How to Create Wi-Fi Access Point (Virtual Wireless Hosted networks) and use it on Windows 7, and if you find something more with this then you are Welcome to share with me and if you face any difficulties share it with me i will help you out..
Jun 01, 2011 | Computers & Internet
I don't remember my network key,so I cannot use it
Try to connect you computer with an Ethernet cord. If the Internet is working check the default gateway of the computer by typing "ipconfig" on the command prompt. Type the default gateway on the address bar. There you will see the login page for your wireless router. Check the default username and password from the router's manual and enter it. If it accept the user name and password, look for the wireless settings, password should be seen there. If not create a new one. If default user name and password doesn't work reset the router. There should be a reset button or pinhole on the back of the router. Press and hold it for 10seconds. Try again typing the default gateway on the address bar then re enter the default user name and password. If it work your router now do not have a network key (unsecured). You can create a new network key on the router's configuration page.
May 21, 2011 | Computers & Internet
I cannot connect my Literati to WIFI
Ok! This is what I fund out personally. The WiFi connection needs to be a non-hot Wifi network. Meaning certain Wifi connections have a security lock preventing any file transfers. I tried several locations to make a connection (Coffee shops, Mc D's, Library, Work, etc.). The Best wy to connect your Literati is to find a friend who has a WiFi ruouter and ask him/her of there password temporarly.
Now you need to enable the Wifi under the settings area by hitting the menu button ans scroll down to the settings tab. select the Wifi or wireless option. Enable the Wifi and your unit should start scanning the area networks. This is where you'll find your friends link or an open unsecure network. Do not select any links that have a pad lock unless your know there password. Once you join, wait about 1 minute and the unit will prompt you to update the software. From here it all down hill..
The Hopeless Literati Guru
Dec 26, 2010 | Sharper Image Literati Reader 16375680042...
I cannot connect to wifi in my ipod touch
Change the router encryption or create an encryption as WEP using your Zyxel router.
The connection in your college is maybe unsecured or no security?
- Try also to check the settings of your router make that unsecured or configured a WEP encryption to the router.
- Turn off the MAC filtering of the router (Under advance settings)
- Disable the wifi-protected setup of the router (Under advance settings)
- Refresh the network list before reconnecting to the network.
Note: As we try WEP encryption to some of the router, the IPod can connect to the network.
Mar 08, 2009 | Zyxel P660HW-D1 Router
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
