Question about Moen & One Handle Tub & Shower Faucet
My single handle tub/shower faucet fell off. I can slip it back on to turn the water on and off, but it will not stay on. I need to know how to get it to stay back on. I tightened that small screw on the bottom, but it did not solve the problem.
    President:
  • 3,433 Answers
Popthe center out and there should be a screw under it. See if that's true and tighten it if so.
Posted on Nov 18, 2009
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
The hot and cold are reversed on our single handle shower (no tub faucet -- shower only)
Hot on left.
Cold on right.
Some single handle faucets have bleed-over where both hot and cold enter mixing valve each time handle is turned on, even when faucet calls for just cold or just hot.
Otherwise maybe a do-it-yourself plumber got pipes backwards... or maybe the tub used to be on other side of wall, and tub was moved during remodeling but pipes were not changed.
To fix problem:
First of all, turn off shower faucet. Turn on Hot at sink and put ear against shower faucet listening for sound of water flowing through the mixing valve.
If mixing valve is working fine, you need to open wall and investigate more.
For example if you have access door, reach in and feel which pipe is hot.
Pipes might need to be reversed if problem comes up in home inspection, otherwise the problem will not harm anything.
Feb 19, 2011 | Price Pfister Plumbing
We have Delta brand tub/shower fixtures, the one handle kind. The problem is that water comes out of both the tub faucet and the shower head, even though the shower is not turned on. This happens every...
You need to replace the tub diverter/spout. There are two kinds, I hope you have the kind with
an allen head set screw on the bottom side of the spout near the shower wall. These are super
easy to replace ! Loosen the set screw, twist the spout a little and it should slide off. When installing
the new spout, smear some vaseline on the copper pipe sticking out, this will help seal the new O rings in the spout.
The other kind of spout has pipe threads in it. They can be a little more tricky. I got called to a
house one time. The plastic female threads on the spout cracked when the plumber installed it.
The water ran down the inside of the wall and did damage down stairs. The leak could not be seen
until the sheet rock down stairs fell down from being soaked. You need to put some pipe dope on the threads, then tighten the spout on by hand, so as not to scratch it with a pump pliers.
I hope this helps !
Nov 03, 2010 | Delta & Single Handle Shower Faucet
No cold water, Only hot water in showers.
The plumbers screwed up when they installed your showers. There are two connections on each shower. one for hot and one for cold. they connected the two hot water lines together with a T fitting and then ran a line to the main hot water line and tied it in. Then they connected the two cold water fittings with a T and ran that line to the main hot water line and tied it in there instead of into a cold water line like they were suppose to. This is the only possible logical solution to this problem. They tied your cold water connections to both showers into a hot water line instead of a cold water line.
Jun 01, 2009 | Danze & Single Handle Tub And Shower...
Single handle tub/shower leaked, now not working
you may have installed the stem incorrectly or something is blocking the water passages inside
Apr 11, 2009 | Plumbing
Tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Nov 09, 2008 | Banner Faucets Pro Series M580 Single...
Moen & One Handle Tub & Shower Faucet  Logo
1,377 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
