How to fix The screen the screen is off no start.
  • retehina May 11, 2010
    General Problem
    » Hp Laptop's Solution » Compaq Laptop's Solution » Acer Laptop's Solution » Dell Laptop's Solution » Toshiba Laptop's Solution » Asus Laptop's Solution
    » Gateway Laptop's Solution » IBM Laptop's Solution
    Driver Download
    » Hp Driver's Download » Compaq Driver's Download » Acer Driver's Download » Dell Driver's Download » Toshiba Driver's Download » Asus Driver's Download » Gateway Driver's Download » IBM Driver's Download
    terebin9
  • Jon Hunter May 11, 2010
    Is the laptop starting but not showing an image? Please give as much info as possible.
Problem with windows starting up with blue screen
Update drivers that control your PC. If problem still persists then use a system utility tool like RegInOut, it will fix the following problems in your PC:
  • Application runtime errors
  • Windows crashes
  • Blue Screen of Death (BSOD)/ STOP Errors
  • Automatic system reboots
  • Failure to start your computer
  • Programs refuse to start
Hope it works for you.
Jan 03, 2012 | Coby 10" NBPC1023 Netbook PC
Aftr i start n log onto my pc... I can see d mouse but d entire screen is blank!!! Pls say what to do
We wish you a merry Christmas and a Happy New Year.
Which is the operating system?
What exactly happens when you start the PC?
Is it Blinking cursor with a black screen?
Then its black screen error.
Firstly, there appears to be many causes of the black screen issue. The symptoms are very distinctive and troublesome. After starting your Windows 7, Vista, XP, NT, W2K, W2K3 or W2K8 PC or server the system appears normal. However, after logging on there is no desktop, task bar, system tray or side bar. Instead you are left with a totally black screen and a single My Computer Explorer window. Even this window might be minimized making it hard to see.
If you have these symptoms you can safely try this for free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below:
1) Restart your PC
2) Logon and wait for the black screen to appear
3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this)
4) Press the CTRL, ALT and DEL keys simultaneously
5) When prompted, Click Start Task Manager
6) In Task Manager Click on the Application Tab
7) Next Click New Task
8) Now enter the command:
"C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com
/download.asp?GRAB=BLACKSCREENFIX"
Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it.
9) Click OK and your browser should start up and begin the download process
10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue.
11) Now restart your PC and the black screen problem will hopefully be gone.
Hope this helps.
Cheers!!
Dec 31, 2010 | HP Pavilion dv6000z Notebook
My laptop came on but my screen is black. I can hear my coputer on but my screen is staying black.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen.use registry cleaner reg in out to solve the issue
Sep 13, 2010 | HP Pavilion dv6000z Notebook
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
My Action Replay DSi starts up with white screen.
i saw a vid that shows you how you MIGHT be able to fix this heres the link: http://www.youtube.com/watch?v=l7jshKuBcaI
Feb 20, 2010 | Video Game Consoles & Games
After fifa 10 loads and you press to start game
The blank screen can be fixed it is normally down to the display chip getting too much heat, you can fix it yourself or you can send it in and Sony will fix it for you.
Dec 31, 2009 | Sony Playstation 3 (PS3) Console
Xp blue and black screen
It seems like you had a software conflict...
Jan 12, 2008 | Microsoft Windows Xp Home Edition English...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
