Question about Panasonic Lumix DMC-TZ3 Digital Camera
Shutter will not open & shut
After being dropped, shutter will not open & close. Can you buy a shutter part? Camera works fine other than that
  • 4 Answers
SOURCE: Lens will not extend
I had the same problem, here is how I fixed it: Make sure batteries are fully charged, Open the cover of memory compartment, the red LED is flashing, it means that there is a reading error. I reset the camera (under the output connection cover), took off the memory chip, and replaced with a spare one, then it powered on and prompt to date/time set up. Let me know if this works for you. John
Posted on Jul 30, 2006
SOURCE: D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Posted on Feb 25, 2008
  • 3 Answers
SOURCE: HELP! dropped camera, lens won't go back in, shutter won't close
I have a camsung L830 that had similar problems and and after I would turn it on, it would beep three times and turn off....but I somehow fixed the lens by turning the camera on and then either pushing/pulling on the part the stickes out and hopefully it might activate the mechanism and it'll go in...that's what happened with mine...the shutters still won't close though. But I'm happy I can use my camera now.
Posted on Jul 26, 2008
  • 3 Answers
SOURCE: Panasonic Lumix DMC-TZ3 shutter doesn't close all the way and gives message "please turn camera off then on again"
My camera got dropped into the dirt. The dirt grains are detrimental to the plastic mechanics of the lens system, they imbed themselves into the plastic and become like sand paper. I took my whole camera apart - something that I would not recommend but I was desparate. I don't think I can save my camera, it needs a new optics.
If the shutter has problems it is most likely that the thin aluminum casing at the front of the lens got bent and you may be able to bend it back with a thin screw driver, that you can manage to insert between the plastic casing of the shutter and the aluminum cover. Just where the aluminum casing ends at the front of the lens. But be careful, you may otherwise damage the aluminum and the looks of your camera. If you got dirt in there, you may want to manually (carefully) open the shutter when the camera is shut off, let it close, etc. while blowing air between the gaps of the shutter blades. You can buy a 'Cleaning Duster' spray bottle from Office Depot and use that. But be carefull to hold the bottle straight, don't tilt it or the liquid content will spray over your lens and you have to clean the oily residue with a solution of soap and water (I had to) and wet a paper tissue (use a Kleenex that is not impregnated with a lotion, on the back of the box it will tell you 'Not recommended for cleanig eyeglasses'.
Hope that helps.
Stephan
If that doesn't work, then you may have to send the camera in for repair.
Posted on Sep 16, 2008
VOTIT
  • 2071 Answers
SOURCE: FE280Power button is pressed camera opens shutter closes shutter
If your camera is still under warranty, the best thing you can dois to take it to the nearest official repair shop and Olympus Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Olympus refuses to repairit for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Olympus Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Olympus Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
VOTIT
DONT FORGET TO RATE;
Posted on Jan 29, 2009
I am not getting an image either through the viewfinder or on the LCD monitor. The display is clear and bright and the batteries appear to be fine.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 26, 2010 | Canon PowerShot S2 IS Digital Camera
Shutter wont close or open fully?! has not been dropped. anyway of fixing this at home? where could we take it to get it fixed? can it be fixed? thanks
If it is under warranttee contact the manufacturer ASAP. Otherwise it may be difficult for you to open it without tools & repair will cost you fortune. Better off buying new one.
aqeelhafeez@hotmail.com
Mar 26, 2010 | Fuji Finepix F50FD Digital Camera
When i turn on the camera the shutter closes, when I turn it off, the shutter opens
I dropped the camera and now the shutter opens when turning off & closes when I open the camera. But when it is open, the shutter will open a bit making it impossible to take pictures. What should I do or where do I take it for repairs?
Tks, Ruth
Sep 11, 2009 | Sanyo VPC-S500 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
View screen black when on & no longer takes photo's
Sounds like a dead CCD. Contact your local Canon service center.
Tom
Jul 24, 2009 | Canon PowerShot S3 IS Digital Camera
Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Memory card shutter wont close
Try closing it with the card removed.
If it will will not close shut, this suggests a piece of plastic has broken off.
The quick fix is gaffer tape it shut.
Indeed it is likely the only fix unless the camera is still under warranty, whereupon it will be replaced
Nov 30, 2008 | Polaroid A500 Digital Camera
Hope that helps.
Stephan
Aug 30, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
I dropped my camera and now the pictures are funny...
What you describe is the symptom of a stuck shutter. The shutter is inside the lens and must close in order for the image sensor to properly record the image. Yours is stuck open, and that is why you see the lines across your images. When a stuck shutter results from an impact it usually requires full disassembly and manual re-setting of the delicate shutter blades. This problem would require professional repair. Unfortunately damage from an impact is not covered by your factory warranty. You can find good repair services on the internet who can service your camera. David Millier Advance Camera Repair
Dec 17, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
20 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
