Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
How do I remove the bottom drawer of my F & P double drawer dishwasher for mounting into the cabinetry?
  • Fisher and P... Master
  • 3,247 Answers
I am assuming you have an integrated double drawer unit DD603I.
The instructions for removal and refit of the drawers is available in the Installation Manual. I am able to locate one on the following site
http://www.fisherpaykel.com/admin/pdfs/pdf_installations/526607O_DD_Install_USw.pdf
You may also need instructions to prepare and fit the front panel of the cabinetry to the drawers which you can down load from
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Hope this is what you are after.
Posted on Nov 18, 2009
Testimonial: "perfect! thanks for the quick response"
My double drawer kitchenaid dishwasher sold red light and beeping during cycle wont turn off and runs even with door open, turned breaker off
If you using upper or lower drawer and this shows up it means the dishwasher has water under the filter board which located on the bottom under the lower drawer. You have to disconnected power,removed the lower drawer, clean the water, replaced filter board, check the dishwasher for leaking.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 26, 2017 | KitchenAid Dishwashers
Keep blowing fuses
This means there is water collected on the base of the dishwasher cabinet under the bottom drawer. You will need to disconnect the dishwasher mains plug and take the bottom drawer out to dry the base out. Follow instructions in this manual (page 7 step 2) to remove the drawer.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jan 08, 2014 | Dishwashers
Fischer and paykel drawer dishwasher has no power to drawer, power at outlet, was flashing F1 prior to shutting down, thanks
If you have a double drawer unit then please confirm what is happening with the other drawer. Most likely the base of the dishwasher under the bottom drawer has flooded and brought down the power with it. The power board sits under the bottom drawer. BE CAREFUL NOT TO TOUCH THE DISHWASHER BEFORE SWITCHING OFF THE MAINS POWER SUPPLY TO THE DISHWASHER AS THE CIRCUIT MAY BE LIVE AND GIVE A SHOCK. You will have to take the bottom drawer out and see what is happening under it.
Jan 16, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel DD601v2 dishwasher
here's the manual..
i did not read thru the whole thing but there are quite a few removal items that i'm sure will lead you to drawer removal.
Hope this helps you.
https://www.scribd.com/doc/6462163/DD601V2-Manual
Jan 22, 2018 | Fisher and Paykel Dishwashers
Disherwasher double drawer has a F1 fault have turned off power and back on again and has stopped beeping but faultF1 and spanner logo still showing ,help please
I am assuming the F1 fault is showing on both the drawers.
This is normally due to flood switch at base of dishwasher housing getting set.
This is due to water leakage from the drawers into the base. To clear it you need to turn power off. Take out the bottom drawer and dry the base of housing with towels and hair dryer. The flood switch is mounted on power board at the base.
Put drawer back and turn the power on. The drawer removal is done by taking out 2 plastic plugs one on each side of drawer and taking front cover off. Then pull drawer out and unclamp from rails. Pull out carefully without damaging houses and wiring a the back. Put back in reverse.
Nov 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F&P double drawer (DD603) won't empty
Ok you need to remove the motor rotor it's under the spray arm and comes out like a light bulb from the top draw and check for anyting stuck under it or any damage done to it. Try swapping it with the one out of the bottome drawer and see if that works. When you first start the washer does it drain all the water?? if still no luck try swapping the motor contoller modules (computer board) from the top drawer to the bottom drawer and retry both drawers ,if the fault moves drawers with the part, then that part is faulty cheers
Mar 18, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher&Paykel DW lower drawer leaks.
hello have you levelled the front and back feet you need to remove the bottom drawer again for this? Is the metal arm that holds the wires behind the drawer still conected to the white plastic wire clamp half way down the loom? check the lid seal has no dents or rips in the rubber seal. cheers get back to me if you still have no luck.
Mar 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Securing Bosch SHU 4300 under "hard" countertops
If this is a new Bosch Dishwasher then there should be two metal tabs that protrude from the top of the tub above the door. These tabs are for top mounting the dishwasher to a wood countertop, however these tabs also can be relocated to side mount the dishwasher to the cabinetry. The way to do this is to pull the dishwasher out of the hole it is in, in the counter (be careful not to pull too hard or to move the machine out too far due to the length of the water and electric lines). just pull it out easy till you can see the tabs, Now using a pair of pliers, bend the tabs on the backside of the mounts straight so you can remove them from the framing of the dishwasher. Next look at the tabs there should be a perforation where you can use 2 pairs of pliers to snap the tabs off at the perforation, after snapping off these tabs, look at the sides of the dishwasher and you will see a slot where you can reattach the tabs into, and bend the tabs in the back to hold them in place. If you look at the rubber gasket material on both sides of the machine - you can see where the round holes are located for side mounting. Attach the tabs and gently push the machine back into the cabinetry. Now using a small drill bit, drill a pilot hole into both sides of the cabinets to mount the dishwasher. You want to drill these pilot holes so as not to split the counter facing when you drill in the screws. Using the Bosch screws that came with the dishwasher (or small flat phillips screws) slowly screw in the screws into the sides of the cabinetry. When you attempt to remove the machine from the cabinetry you may find that it is adjusted tight to the countertop. If this is the case you will need to remove the 2 screws that hold the kickplate in at the bottom of the dishwasher in the front and remove the kickplate. Then you will need to bring up the front legs on both the left and the right and also the rear leg which is adjusted up and down by using a flat blade screwdriver. Look at the front of the dishwasher, behind the kickplate and there will be a adjusting screw with arrows which point left to right. the direction you turn this screw will determine which way the dishwasher will adjust,- right adjusts the machine higher and left lower. Good luck!!!!!! Hope this helps.
Feb 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Fisher and paykel twin draw
I'm not really sure. With the double drawer configuration, I know the top drawer is larger than the bottom drawer. If I had to take a guess, I would say the single drawer might fit in the top of the double drawer.
Jun 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
295 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
