Question about HP OfficeJet 6210 All-In-One InkJet Printer
I never installed the software( I don't think) to set up the scanning options for my hp 6210 all in one. how do i go about being able to scan with no disk because I think I have mis placed the disk? thx
  • 58 Answers
Find and buy an installer for it...
Posted on Nov 18, 2009
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
When go to the scan to button it says no scan options officejet 6210
" no scan options refer to device documentation for trouble shooting"
you need to open up either solution center or hp director, go to settings, scan settings, then scan to set up and look for the option front panel destination a window should open to reveal scan short cuts and one titled front panel list. you need to select the shortcuts click add and once satisfied click on "update device".
Mar 27, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Scanner doesn't work. It says no scan options,
You can check if the scanner driver is still installed by going to Control Panel\Scanners and cameras (if you have windows vista, you need to be in "classic view" in control panel)
If you see the HP scanner listed there, you can double click on it to run the windows scan wizard.
If this works you just need to find some scanning software, not necessary the HP one.
If there is no scanner listed, you will need to download the software and drivers which you can most likely find on the HP website.
Mar 25, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hi, I have had my hp 6210 for several years and just re-installed it. When I try to scan, I get the message: "No Scan Options. You need to run or install software for feature" Thanks, Johnny
Visit the below web link and select your operating sytem, download full feature drivers.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=421991&lc=en&cc=us&dlc=en&lang=en&cc=us
1. If the issue still persists, After installing the printer software
2. Open HP Solution Center
3. Go to Settings-> Scan Settings->Scan to setup
4. select all available scan shortcuts one by one and click on add
5.Click on update the device
6. Verify the results.
Aug 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
No Scan options
launch hp director to configure scanner profile
Nov 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Can't Scan with my HP 6210 All-in-One
Hi Kal,
I've included a procedure to get current drivers. But since your 6210 has been working, I thought we might try this first. The following link will bring you to a page describing an HP utility that specifically addresses your problem. Read through it and follow it's lead.
HP Scan Diagnostic Utility
For the correct 6210 drivers:
Click this link for for HP Software & Driver Downloads page.
Once there, select your Operating System (XP)
The next screen will offer several download options:
Under Drivers:
Select the appropriate driver for your application/situation.
Be mindful of the download sizes. One of them is pretty hefty and could take a while.
The first option should take care of your scan problem without all the reinstall turmoil. But, if it doesn't, option two will.
Any problems, let me know. We'll handle it.
Hope this helps
Mike
Jul 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
