Question about Car Audio & Video
How to run an amp wiring kit in a mitsubishi verada ei 1998?
How is the best way to run an amp wiring kit in a mitsubishi verada ei 1998?
Where to find hole from enginebay for power?
Where are the best positions?
Where to run remote, power and RCA plugs?
    Problem Solver:
  • 5 Answers
For the power wire try running it thru where your factory wiring harness go thru for the rest of the power or you may need to make your own hole... for the others,, pry up the side molding by your doors that are plastic, lay them under those very flatly so it'll still clip back in and you may need to run them on both sides if your power wire is thicker then 6ga.
then just try to run them underneath plastic moldings all the way back.. you can pull up your carpet if you really want to but its a lot of unneeded work if you go thru that way
Posted on Nov 19, 2009
My 2000 tj magna sat for 2yrs Replaced with new battery was hard to start...drove 50klms turned off....now all it dose is crank over and wont start
I think you should buy repair manual first for your vehicle after that it will be easy for you to solve the problem. Check the link may be you will find something useful here
Complete Mitsubishi Magna 1998 2001 TH Series 1998 2002 TJ Series Verada...
Nov 29, 2017 | Cars & Trucks
Hi i have a mitsubishi verada 1998 it wont idle down can anyone suggest wat it might be
wow an oldie but a goodie !!! 1998 !!! first id look to make sure the throttle isn't stuck , old aluminum gets corroded and likes to stick a bit then id look 4 any cracked and broken hoses on the manifold , if any of these leak air it will high idle
Aug 03, 2016 | Mitsubishi Cars & Trucks
Do I need to get a new head unit to put an amp and subwoofer in my mitsubishi verada?
Amps have a high and low input. You can run some speaker wire from your rear speakers to the high input on your amp. It comes with a small white plug with four wires. Use the green for one side, and the grey for the other! So no, you do not!
Jan 24, 2013 | Cars & Trucks
Can someone please give me the code for my radio Mitsubishi verada 1998 model radio model no AW345090 serial no 284004908.5.
Go to a Mitsubishi Dealer with your car, prove the car is yours and the dealer will give you the code, they will not give it over the phone.
Feb 18, 2012 | Mitsubishi Car Audio & Video
Blown fuse mitsubishi verada 1998
It could be as simple as the brake light switch located at the brake pedal and under the dash.
They go bad from time to time.
Dec 21, 2017 | Mitsubishi Magna Cars & Trucks
Hi there how can i tell if i cracked my engine block on a mitsubishi magna/verada 1998 can see coolant between the heads but dont know where its coming from
Blocks rarely crack, heads do crack more often. Most likely you have blown a gasket. Unless you can see coolant coming from a crack , you will have to disassemble it to find out
Aug 31, 2011 | Mitsubishi 3000GT Cars & Trucks
Starter Motor Verada V6 ei
i do not have one handy but the starter will be located at the point where the motor and the transmission join. on either side of the motor. follow the main line from the battery to make it easier to find. if you are replacing it post another question and i'll do my best to answer it if i see it come up.
robert
please take a moment to rate this solution.. thanks
Nov 30, 2009 | 1991 Mitsubishi Galant
I have a 4 channel amp which i would like to install myself in my 1998 mitsubishi verada ei. how do i do it?, because I cant find a hole to run my power cable from battery to amp. Where would the best...
really depends a lot on you if you have clearance you can put it under a seat eaven a 500w amp wont get that hot down there. As far as your powering wire you can some times find a rubber plug in a hole on the fire wall or you can drill a 3/8-1/2 inch hole depending on your gadge wire and use a rubber gromet to protect the wire. the ground can be any steel part of the car generally I use a metal self tapping screw to the floor steel.
Apr 13, 2009 | Car Audio & Video
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
