Question about Philips 32MF231D Television
WHAT TYPE OF REPLACEMENT CAPACITOR DO YOU USE FOR A MAGNAVOX TV MODEL NUMBER 32MF231D%2F37
  • 11,361 Answers
If you are working in the switching power supply and need electrolytic, I would use PANASONIC FM series for very low ESR, High ripple current rating, 105c temp. Get them from www.digikey.com
Posted on Nov 18, 2009
Power light is on but no picture or sound and screen flashes
The most common cause of this issue is a failure of the filter capacitors on the power supply board. The board is repairable by replacing the bad capacitors. This will require a little soldering but should only take about 20 minutes total time. Here is a link to a repair kit with the correct capacitors \for that model.
http://www.ccl-la.com/catalog/product_info.php?products_id=323
Mar 23, 2013 | Magnavox 32mf231d
MAGNAVOX 32MF231D TV PIXILATES, THEN GOES BLACK, ON AND OFF?
Hello Kevin,
That type of issue is usually caused by bad filter capacitors on the power supply board. As the capacitors heat up they can't filter the output power correctly so the power supply shuts off to prevent damage. Here is a link to information and parts list of the capacitors neede3d to repair the power board.
Feb 19, 2013 | Magnavox 32mf231d
I have a 32" Magnavox tv purchased in 2005, model
dear User,
pls be informed that supply capacitor are weak.
kindly change the supply capacitor
Feb 26, 2011 | Philips 32MF231D Television
Television model number 32mf231d/37 does not want to turn on
I have the same problem with the same tv and the problem almost always is at least one blown capacitor on the power board of the tv. U can see for yourself. (be sure the warranty is up for your tv first, if not get phillips to fix this for you) remove the back cover and then the metal top that cover the power board (you will see the red yellow and white AV plug jacks) in there is the power board, you can tell whether or not the capacitor is blown by looking at the top of it, it will be bulging out or leaking. This is an easy fix, u can get new capacitors from radioshack or stores similar to it.
Aug 16, 2010 | Philips 32MF231D Television
My magnavox 32mf231d/37 tv will power up and the sound works, but the screen is blue... any help would be great!
Try taking it for a walk, or sing happy songs to it.
Depression is a common problem with today's LCD panels.
Most cases go untreated.
Talk to your doctor about receiving medication that may be able to help with it's symptoms. Side effects include nausea, diarrhea, genital warts, hemorrhoids, and an erection that lasts longer than 4 hours.
Do not watch your TV if yo are pregnant or using an MAOI, as these combinations have been known to cause permanent death.
Jan 27, 2010 | Philips 32MF231D Television
Power light flashes but TV does not come on: no picture no sound. 34" HD Magnavox 32MF231D/37
Check if it the picture may be just faint. If it is it may be a bad ballast or weak back light. If there is none at all, it may be a problem with the power supply. This is the first circuit after the power chord. There may be loose connections, leaking or swollen capacitors or burnt resistors or the IC or the entire circuit may be bad. This is a common issue with these type of devices. While at it check the rest of the circuit for the same items. There are cases where the problem is with the main board.
Dec 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
TV WANT COME ON LIGHT JUST FLASHES.
you are definitely having the same problem I"m having with my samsung.. Cheap capacitors. You will need to replace your powerboard with something similar to this:
http://cgi.ebay.com/Magnavox-37MF231D%2F37-Power-Supply-REPAIR-SERVICE_W0QQitemZ350261990220QQcmdZViewItemQQimsxZ20091007?IMSfp=TL091007138002r8521
I recommend watching a video on how to take it apart and remember to be VERY CAREFUL there are high voltages stored in the capacitor banks even when it is not plugged in there is still risk of electrical shock.
Oct 29, 2009 | Philips 37MF231D 37 in. LCD Television
32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
Televison & Video Logo
749 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
