Question about Dell UltraSharp 1907FP 19" LCD Monitor
Where can I find an on/off switch for my Dell 1907FP monitor?
  • 732 Answers
Sholmes, Try Digikey.com or Mouser electronics. You WILL match it up exactly and may need to do some tricky "unsoldering" and "soldering". Good luck! YOU'RE on your OWN. 12fixlouie.
Posted on Nov 18, 2009
Testimonial: "Short and to the Point. Doesn't dress it up with a bunch of tech jargon. Thank You!"
Dell ultrasharp 1907fp bad contrast
I have seen a few of these monitors that when the display is dark in certan area's this usually indicates that one of the CCFL lamps has gone bad or there is a problem with the Analog/Digital Board, you can find the boards on ebay, but be VERY Certain that the board you order is the same that you take out of the monitor, as there are a lot of monitors that use the same simular boards but they are all different.
Sep 24, 2012 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell LCD 1907FP 19" have
Unfortunately this is an early indicator that the LCD display panel is starting to break down and the cost to replace the part will exceed the amount of a new monitor. I recommend using present item until it completely fails. Sometimes the video cable is the issue and should be subbed provided you can detach from both ends.
Sep 06, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
I do not know how to make my dell monitor usb ports active please help me
  • Check that your monitor is turned ON.
  • Reconnect the upstream cable to your computer.
  • Reconnect the USB peripherals (downstream connector).
  • Switch off and then turn on the monitor again.
Jan 19, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Power Button Broken?
Yes, I think your right, if it is under warranty send it back to Dell for repair, I had the same issue about a year ago.
May 20, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Height adjust for Dell UltraSharp 1907FP 19" LCD Monitor
Is it stuck, or just not adjustable? Try setting it on a phonebook. I'm kidding. If it is an adjustable base, sometimes they need a little downward pressure before the button will depress and allow it to move upward.
Thanks,
Chris
http://BoiseLCD.webs.com
Jan 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907fp USB port not working
The big question is do you have the USB uplink cabled from the monitor, connected to a USB port on the system?
http://support.dell.com/support/edocs/systems/1907FP/en/about.htm#Bottom%20View
Item #5 needs to be connected to your system's USB port via a USB cable. The ports on the monitor are just a USB hub.
Jun 09, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907fp picture "shifts up"
It is most likely the cable, it is where most faults of this ilk lie in LCD monitors. :-)
Mar 27, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
236 people viewed this question
Alun Cox
