Question about Kenmore Refrigerators
Do the kenmore refridgerators have a daily defrost cycle? If so, how long does it last and what is the temperature fluctuation? The freezer is empty right now, and the temperature fluctuation seem to go from about 0 to about 40 is this ok?
  • Kenmore Master
  • 1,606 Answers
A defrost cycle , lasts about 28 to 32 min . It will go into defrost either every 8 , 10 , or 12 hours . The temp in the freezer , can be anywhere from 45 - 100 degrees , depending on the frost build up , due to times it's opened , and length of time opened . The frozen food , in the freezer , is what actually keeps the temp low . No food in the freezer , and the temp will be high . GE , is the only brand that uses 140 degree defrost thermostat , but that is altered by the thermistors .
Posted on Nov 19, 2009
  • 520 Answers
All refrigeration products have a defrost set point. Most residential units defrost about every six to eighteen hours. This process should take about 30 minutes to 1 hour. The temp goes up so high inside because there is a heating element in the coils to thaw any residual ice. The temp should not exceed about 45 degrees though. If it does the the compressor is signaled to come back on and start cooling again. This is perfectly alright. The time at higher temp is not enough to spoil the food. Hope this helps. Good luck.
Posted on Nov 18, 2009
Several times now my freezer & refrig. stopped working. Ice buildup on back of freezer wall. Especially if there is content in it. The icemaker I think was spilling water down the back (missing the...
Sounds like one or more of you defrost coils behind the back wall have gone bad...
You have to purchase the correct coil set for that model, remove the back wall, replace them and put the back cover back in place after emptying the entire contents of the freezer...
Most non HVAC people would prefer a repairman to do it.
Mar 09, 2014 | Kenmore Top Freezer Refrigerator
The freezer wont go to it's normal temperature and alarm keeps beeping!
either its not defrosting or its low on freon, is there frost anywhere in the freezer, such as the back wall?
Feb 04, 2013 | Freezers
New upright kenmore freezer temp varies +/- 10 degrees
Over what period of time did this variation occur?
The freezer should have an automatic defrost cycle. The temperature will rise while it is going through this cycle.
Oct 18, 2009 | Freezers
1 yr old Kenmore fridge (18 cu ft top freezer mdl 970-41924) has very long defrost cycle - freezer contents partially melt, fridge warms to 50-55 F. (Normally runs at 38-40 F.) We keep several litres of...
Either the defrost timer is going out or it could be your defrost bimetal thermostat that is located behind the back wall in your freezer. Both parts are cheap and easy to install. I would replace both.
Sep 09, 2009 | Kenmore Refrigerators
I have a kenmore refridgerator side by side. The freezer is beginning to have snow buildup (it is a self defrost) the refridgerator side is not cold
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Could you find a model number like 321.256489 for example then I can find the parts to look for. Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Kenmore Refridgerator Freezer Condensation
When I observed this issue, I found the freezer not running the defrost cycle enough times, (maybe this was in the spirit of conserving energy Energy Star compliant???))
If the Defrost is working, use the diagnostic test, that may be all you need to do until the next build up of frost on the coils.
Aug 17, 2009 | Kenmore Refrigerators
Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
Aug 13, 2009 | Kenmore 56176
Ice builds up on evaporator coils. After chipping off the ice, refrigerator is cold again. This lasts only a few weeks as ice builds up. Eventually, the freezer is cold but the refrigerator is very warmer....
Assuming this was originally a frost-free model, either the defrost cycle timer died or the defrost heating element died. If it's the timer, you might be able to manually start and end a defrost cycle every few days. If it's the heating element, you may be stuck with what you're doing or an expensive repair or buying a new refridgerator.
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
Temp Fluctuations
i wouldnt worry mucha bout the fluxuations in temp, chances are simply a momentary reading perhaps just after a defrost cycle, sometimes new electronics can be a little too sensitive, I would only worry if you actually experience a noticable deiifeence in temp(ie.. your milk doesnt last as long, ice cream not hard as once was,, dairy usually best indicator in temp flux's))) dont worry so much abou the number, unlkess they are consistantly rising without correction
Aug 05, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore refridgerator c1065094881
It sounds like your defrost cycle has stopped working. unplug your fridge for 24 hours and let it defrost. plug it back after 24 hour and if it starts to cool in the fridge part at about 40 degrees F. you will have to replace one of three parts the Defrost Timer, Defrost Themo or Defrost Element. I hope this helps you.
Dec 22, 2007 | Refrigerators
Refrigerators Logo
199 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
