Question about Denon AVR588 Receiver
Help with audio sound
I recently just connected a coaxial audio cable to from my DVD player to my Refeiver (Denon AVR 588), it was working at first then i messed with a couple settings under input, and now i have no sound with the DVD player, and i can't seem to get it back. I put the input levels back to what the manual says are default, but it still won't work. Suggestions please.
Had the same problem - have a 3-yr old Sony DVD without hdmi - used RGB for video (hooked it up directly to tv) and optical cable for audio (connected to OPT-2 in receiver) and problem solved. the standard red/wht audio cables also worked.
Posted on Feb 17, 2008
Denon AVR-1908 speaker issue
Before we play taps and throw dirt on top of the Denon, perhaps a bit more triage is in order. I'm not certain who the patient is. Especially when you have "speaker issue" in the title. Are you saying there are some speakers that don't work ONLY with BluRay?
If it has NEVER worked the (unnamed) BD player or its cable(s) could be at fault, too.
What 'connections' are we talking about. HDMI, coaxial- or optical audio, 5.1 analog; to what input on the Denon assigned to what function?
Have you tried all audio paths out of the BD player? Is it configured to squawk in the right digital mode?
Do you have any other digital audio sources (CD/DVD) you could use to certify the audio paths that don't work with the BD player?
Apr 08, 2010 | Denon AVR-1908
Denon AVR-786S 7.1 Channels Receiver
First set the DVD player To mono and then see.
Check if the DVD assigned to coaxial input in receiver menu?
Check if the Digital out activated in player menu?
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.
Feb 23, 2008 | Denon AVR-786S Receiver
No audio on Denon AVR-588 from digital sources
If it is set to automatically detect connections then by default it will send signal to the one with the highest bandwidth, much like back in the day when you might have S video and composite connected simultaneously to the same input. So if you have your HDMI input assigned to DVD it will output that over optical or coaxial.
Jun 07, 2009 | Denon AVR588 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Denon AVR 588 7.1-- Sound setup questions
This reciever does not decode the audio through HDMI, the HDMI ports are simply a pass-through. To get audio you need to connect an optical audio cable from the PS3 to the reciever also. I figured this out after 2 hours of trying to get audio from the HDMI cable. Here is a link that shows the different audio formats supported through HDMI by the different Denon models. It looks like the AVR-788 is the lowest model that supports audio through HDMI. Hope that helps.
Apr 03, 2008 | Denon AVR588 Receiver
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
No Audio coming from DVD source
Press the input select button on front of receiver until auto is displayed it may be set for analog. Auto mode will play digital signal first then if it does not see a digital input it will check for analog signal. I would set it to auto for all inputs you may use.
Jan 10, 2008 | Denon AVR588 Receiver
Denon Avr-588 setup
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
Jan 03, 2008 | Denon AVR588 Receiver
Setting Up New Denon AVR-588 / Adding Sony DVD with Component Video cables
Make sure you have receiver switched to proper input as coax rather than digital
Dec 31, 2007 | Denon AVR588 Receiver
No sound from my Denon AVR-1707
I think that's something in SOUND SETUP menu incorrect. Try to redo it again.
Oct 01, 2007 | Denon AVR-1707 Receiver
Denon AVR588 Receiver Logo
129 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
