Question about Air Tools & Compressors
On my kobalt digital air compressor i have 150
On my kobalt digital air compressor i have 150 psi tank pressure but there is a continuous ticking noise for the regulator and it makes it work improperly. i cant even fill up a tire with it
  • 3 Answers
This was a poor design for kobalt with digital readouts.. The compressor waqs made by several comanies including campbell hausfield and porter cable, But some were imported.
There under the controls is a switch that cuts out the motor, It looks like an oil pressure switch on older cars. There is also a manifold tree that holds the guages and the regulator. There will also be a circuit board that holds the electronics for the regulator control.
Remember you have to set a value to bring up the pressure and the board senses the tank pressure and "Bleeds" off via a solenoid to hold the pressure. The ticking sound you hear is the solenoid, ITs not repair/replacable.. its part of the controls.
If the unit is under warranty you might eant to ask lowes who is their off site repair center, or ask is it available to be exchanged.
Personally, and professionally.. this model is oiless, so it has a shorter life as to being reliable compared to oil lubrication. For the extra bucks you will come out with a more reliable and easier to service model.
Posted on Nov 29, 2009
  • andyburnham
    andyburnham Sep 07, 2014
    this is a completely inaccurate statement. You can buy the solenoid online at any of the compressor part websites
Have a old (1950's guessing) westinghouse air compressor. Pumped it to 150 psi, I shut off, air was coming out of air intake and had pressure in the crank case.
replace the non-return valve in the pipe at the tank connection
air out of intake is poor poppet/read valve seating and pressure in the sump is the tank air leaking back and down past the rings
150 psi is excessive and not good for the compressor so adjust it back to 100 -110 psi
Nov 12, 2016 | Air Tools & Compressors
Hello I have a 20 gallon kobalt model 033204. I just replase pressure switch but does same thing. When I tur on the compressor jus build 50 psi and shuts off.
This usually occurs when the motors internal thermal / amp breaker opens due to overload or weak breaker. Use an amp gauge to test for too much amp draw. If amp draw is normal, then problem could be the in-tank check valve leaking pressure back to the pump overloading the system, or weak capacitor or weak breaker. Bypass the breaker temporarily if the amp draw is normal to test system. Good luck
Oct 31, 2015 | Psi Air Tools & Compressors
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
I have a C2001-WK that does not auto shut off
A regulator controls the pressure in the air line leaving the compressor and does not affect when the compressor turns on or off.
The pressure switch monitors the pressure in the tank and turns the compressor motor on and off when the switch closes or opens in response to changes in the tank pressure. If the compressor does not shut off, it is possible the pressure switch has been set to a pressure level that is higher than the compressor is capable of attaining, thus it does not shut off.
The compressor is capable of developing 150 psi and is noted as having a "120 psi cut-in pressure". When you say it doesn't shut off, does that mean it will generate 150 psi or more of pressure and fails to shut off or it develops less than 150 psi and does not shut off.
If the compressor does not generate 150 psi, then it is probably somewhat worn out and not capable of developing enough pressure to meet the factory high pressure limit. I would try adjusting the pressure switch upper pressure limit down to 130 psi or less (less if the compressor will not develop 130 psi) and see if this solves your problem If it doesn't,
If the compressor will develop 150 psi or more, then try adjusting the high pressure limit to less than 150 psi. If you can't adjust the high pressure limit then the pressure switch is defective and needs to be replaced.
Aug 03, 2012 | Porter Cable Air Tools & Compressors
Compressors
The pressure regulator on an air compressor is designed to let the pump motor run until the pressure in the tanks reaches their safe level. While you are using the air the pressure drops in the tanks until it reaches the level where the pressure switch turns the motor on again and refills the tanks to their rated level. The pressure where these two things happen is usually with in ten psi above or below the rated levels because few regulators are so precise and are affected by temperature that they turn and off exactly at the rated pressures. If a pressure regulator is damaged or broken it is possible for the tank to either reach unsafe high levels or not turn on when the pressure drops to where it should restart the motor. If you are in doubt, have the regulator checked or replaced as overpressured tanks are very dangerous.
Jun 24, 2012 | Craftsman 150 PSI Air Compressor
My psi is 150 and the tank turns off but my regulator pressure is at 0, this is a brand new tank and never been used before.
Hi scooterb88...
Sounds like your pressure regulator needs adjustment...
Turn the knob on the pressure regulator clockwise and you should start hearing air coming out of your hose...Once air is coming out, remove your hose and keep turning the regulator till you get to your desired working pressure normally around 90 psi...leave your pressure regulator at that setting and it will stay at that setting.
Please take time to rate me
Sep 17, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Pressure builds to 150 psi but the regulator will not increase above 60 or so psi. this is causing the nail guns to not shoot correctly.
When the regulator fails, usually air will leak from under pressure knob, however in your case the nut must be stripped of its thread. May need to replace the manafold for fix(most regulators are built into manafold). To allow you to continue using the compressor, add another quickconnect at pressure release port. Let all air out of the tank. Remove pressure safety release, and install tee fitting. Re-install pressure safety on one of the ports of the tee fitting and a quickconnect at the second port. You will have tank pressure available while you order the manafold. Or just add a generic regulator before the quickconnect and forget about replacing manafold. Good luck.
Aug 20, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Kobalt air compressor will not go above 80PSI
if this is an older or much used unit, cylinder/piston may be worn, unable to push higher psi, which would explain no leaks. if newer unit, seems like regulator unit/valve faulty
Jul 24, 2009 | Air Tools & Compressors
Kobalt air compressor won't run
hi mate take the head off and inspect the valves and gaskets i had this problem and it was the gaskets gone just make sure the valves are opening and closing ok good luck
Jul 23, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
754 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
