Question about LG CU400 Cellular Phone
I dropped my phone in water but icked it up right
I dropped my phone in water but i picked it up right away and dried it now that i turned it back oon it say emergency download..what do i do
  • ghetto_booz Jan 02, 2010
    omg i have never tryed that..well i got my phone to turn on...but if my phones die it wont turn on it will say emergency download...so if i still do that will it still work??
  • 10,865 Answers
Remove the battery and immerse both the phone and the battery in dry uncooked rice for three days. This is the only cheap way to dry everything out. After the three days put the battery back in the phone and it should be OK
Posted on Nov 18, 2009
How can I revive a phone that has been dropped in a betadine /water solution
The rice is supposed to dry it out. If you can get the back off you can dry some of the inner components with a lint free cloth. Be very careful not to break or bend the pins that hold the battery in.
May 16, 2015 | Cell Phones
How to treat my Betta fish ick
  1. The first thing you should do is remove your betta from its current tank. You will want to set up a separate temporary container to house your betta while you clean his regular tank. Be sure to use clean water that has been treated with water conditioner. If a separate tank is not available, you will want to do a full water change on the tank along with a thorough cleaning. Again, be sure to add the appropriate amount of water conditioner before adding your betta back to the tank.
  2. Ick thrives in cold water, so after you have a clean tank setup, you will want to install a tank heater to warm the temperature gradually to 82 degrees. Be sure to use the proper size heater for your tank size. Also, make sure the heater has a cut off switch or something to keep the temperature from going over 82 degrees. You don't want to cook your fish!
  3. Now you are ready to treat the ick. You will need an antiparasitic medication. Try Kordon Rid Ich Plus you can pick it up at most pet stores. If they do not carry it, ask for another antiparasitic appropriate for betta fish. Use according to package directions.
  4. Continue treatment according to directions.
How to keep ick away:
  • Continue using heater to keep water at 82 degrees
  • Do frequent water changes with water conditioner added to clean water
  • Use aquarium salt: it is inexpensive and easy to use. Purchase from pet store and follow package directions for use.
    Good luck! I hope your fish gets better!
Mar 01, 2015 | Marina Aquarium Cubus Desk Fish Tank Betta...
My phone drob in water what can i do
try putting it in a bag of dry rice for a few days. it will take the water out of phone. remove the battery if u can. my son dropped my new iphone in water and this fixed it
Apr 06, 2014 | Nokia C203
Dropped it for 2 seconds in the shower...picked it up right away.....water seems to appear on in the screen....what to do ?
Hi, when ever a phone drops inside the water, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.
You will need to service the phone for the phone to be free from water,cause if the water dries inside the phone it will damage an IC or a chip inside the phone and it might cause more damage to the phone.
After, disassembling the phone is the next step.
Get a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.
Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
After some minutes,assemble the phone back and fix in the battery. Make sure during the processyou are charging the battery of the phone.
I guess that's all you need.
Note: if the battery has stayed too too long on the phone and am sorry after the water splash, it might not come on after this all process, that means you will have to flash the phone because the battery might have damaged the memory of the board of the phone and will not power up the phone because the phone is too weak to power.
Flashing of the phone will restore back the phone memory.
You can visit the below link to learn more about flashing of phones.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Hope it helped.
Feel free to pass your comment.
Thanks for using fixya.....
Jan 21, 2011 | Cell Phones
My LG Neon got wet is now really messed up
I had the same problem and fixed it rather easily, the problem is that the componants are wet and need to be dried, if you send it away your warrenty will be flaud as it is wet and all they will do to fix it is pull it apart and put it in a drying machine so i advise you to wrap it in a towel and place it somewhere warm like a hot water cubboard or directly in the sun, it needs to completly dry. you could try wrapping it in a towel and use a hairdryer on a low setting to dry out the componants, remeber to stop and let it air evey now and then or you will get condensation on your screen, hope this helps
Dec 22, 2009 | LG Neon GT365 Cell Phone
HELP dropped my phone in the toilet
pick out the battery and sim and dry it off properly and dont try to start i again for att lest 3-4 days and then se
Jul 28, 2009 | LG RUMOR Cellular Phone
My Phone Fell down in the Water what do i do ?
Turn off the phone imediatly if its still on. open up the phone by taking off the covers and unscrewing them. bring a hair dryer and dry the board then when its completely dry, use a toothbrush to brush any resedue off of the board. then spray it with any type of alcohol product and brush it again with the toothbrush. cover the phone and turn it on.
Jan 03, 2009 | Nokia 6600
I dropped my MP3 player in a puddle of water. I
Even drying doesn't usually help. Water kills electronics - period. That is the only solution I can offer, because that is the only correct answer.
-Tha Mp3 Doctor
Dec 18, 2008 | RCA OPAL M4001 MP3 Player
Dropped razor in toilet
Sounds like it is done for, yes. I know a way to save electronics if they are dumped in water, but it requires to fill it with water replacing fluids. Putting it in pure alcohol right away (remove battery first) might save it, as ir should replace the water and then evaporate completey when you take it out. Some contacts have probably corroded in your phone, so unless you are (or know) a repairman of electronics you'll probably need a new phone. :-/
May 16, 2007 | Motorola Mobility V600
LG CU400 Cellular Phone Logo
112 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
