Question about Whirlpool ED2NHGXM Side by Side Refrigerator
Both the refrigerator and the freezer have stopped cooling. the lights and fan work. i've tried to clean the coils. is there anything else i can do before paying the big buck for a repairman?
  • susanc426 Nov 18, 2009
    there is no ice or frost in the freezer. basically the entire interior is room temperature. i do hear a clicking noise every once in a while.
  • Richard Bedwell May 11, 2010
    you nead to tell me more.is there ice or frost forming on the back wall of the freezer.do you hear the compressure trying to come on and than clicking off.
  • Whirlpool Master
  • 1,606 Answers
Pull the refrig out and remove the lower panel . On the side of the compressor , is a piece plugged onto it , with 2 or 3 wires . This piece is the problem , pt # 2188831 . It is easily replaceable , avoiding expensive repairs . Cost of part , is around $ 30.00 .
Posted on Nov 19, 2009
  • Mike Smith
    Mike Smith Nov 19, 2009
    richabedwe : you are supposed to be the repairman !
    Sergeant:
    Champion:
  • 289 Answers
You nead to call a repairman.
Posted on Nov 18, 2009
My frige & freezer do not cool at all,lights & freezer fan work,compressor & coil fan do not
Hello Friend, this is Z. Thank you for allowing me to assist you!
Based on the symptoms you are describing, it sounds like your refrigerator could have floating restriction in the line or something more complicated like an issue with the sealed system that only a professional can repair. This can include the compressor not working, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. It is typically normal to hear the compressor running, humming, or even to be a little warm. However, if you do not hear the compressor at all, I suggest cleaning your refrigerator out including the coils you can reach (typically located in the bottom behind the toe grille) and make sure no food items are blocking any vents in your appliance. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues. Best! - Chris
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
GE Artica PSS25NGMD Side by Side stopped cooling
Unplug the unit and pull the relay off the compressor and shake it to see if it rattles. If it does, the relay is bad and will need to be replaced. Here is that part to order.
Here is the overload relay that should be replaced also.
Is you pull the relay and it does not rattle, post back the results to me.
Here is a video to help you out.
Feb 09, 2013 | Refrigerators
Top freezer working fine refrigerator part not cooling we've cleaned the coils
Did you check for an ice build up behind the rear panel in your freezer? It sounds like your defrost system is not working and allowing ice and frost build up that is blocking the cooling tubes to the refrigerator.
But also make sure that the evaporator fan in functional so that it forces the cold air from the freezer to the refrigerator through the cooling tubes.
Sep 04, 2011 | Kenmore Refrigerators
Freezer ice maker stopped working. then entire unit stopped cooling, fan is not working. Light is on inside the unit.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ghjd
May 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
My freezer is working but fridge has stopped any ideas in what could be wrong. The coils where dirty I have cleaned them..
Does this unit just have one thermostat? is this a frost free unit? does the cooling for the fridge come from the freezer side compartment via internal fans, if so are they working?
well done on cleaning the coils by the way, did you notice the fans down there running and latent heat being dispersed? (FROM COIL)
Jun 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Whirlpool ED2NHGXM Side by Side Refrigerator Logo
83 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
