Question about Samsung HLP4663W 46" Rear Projection HDTV
Replaced the DLP bulb and the picture only worked for ten minutes
Replaced the DLP bulb and the picture worked for about ten minutes and then went blank. I can see the bulb is on on the back of TV but it isnt projecting image
  • 1 more comment
  • rayski11 Nov 18, 2009
    I did close the door cover, but how do you reset the lamp timer?
    The fan is running ok.
    It could be the ballast. Is that a difficult of expensive repair?
    I got the Phillips bulb
    God Bless you as well brother and thanks for the help
  • Antonio Cruz May 11, 2010
    Hi,did you close the door cover? Reset the lamp timer? Check the fan was running ok? If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able to provide the power to the lamp it will not turn it on and the red light will blink.Also did you get the original Philips lamp if you got a generic that could be your problem.God bless!
  • 336 Answers
Hi,again,Thanks for the blessings.One quick way that works for most sets its to unplug the set wait 5 min and plug it back again.Here's instructions to replace the ballast: http://guides.fixyourdlp.com/samsung/bp47-00033a.php Found ballast here: http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1139281.htm?Click=48173 Pay attention to other sounds like buzzing or whirling because it could also be the color wheel.God bless you and your house! Let me know if you need further help. r2d2repair@gmail.com
Posted on Nov 18, 2009
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
I have a dlp 73in mitsubishi tv and i have sparking in the long box next to the bulb housing
check to see if the lamp connectors inside the lamp compartment didnt get pushed back inside the set. If they are still there secure inside the lamp compartment then you will need a new ballast which you can get from www.tvrepairworld.com
Feb 22, 2012 | Mitsubishi WD-73732 73" Television
Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
Feb 03, 2010 | Toshiba 62HM95 62" DLP HDTV
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Jan 24, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Black screen with a Blinking lamp in the front
Hi..if your lamp is on but no picture, then your lamp is good. Your problem is the DMD board (digital mirror display board) is bad. This is very common with Samsung DLP.
Mar 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
191 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
