Question about Brother DCP 130C All-In-One InkJet Printer
Memory Stick I have a Brother DCP-130C printer and want to use a memory stick to transfer data and photos. I don't seem able to do this using the USB port on the front of the printer. Can this be done or do I have to use a USB port in my tower?
  • 832 Answers
Dcp 130c cant transfer plain data. Its a pic bridge (digital camera standard) connection only.
You have to use your PC USB.
Posted on Jan 10, 2008
Brother dcp-130c flat cable
if you want to damage your device you can use tin instead of gold.
Jan 22, 2014 | Brother DCP 130C All-In-One InkJet Printer
I have a dsc-w150 digital camera, no usb cord. how can i transfer my pictures to laptop?
You'll need a card reader to transfer the data to your PC.
These days most laptops and printer has built in card reader. But since Sony camera's use memory stick, some of them don't support memory stick. So,
  • First check whether or not your printer or laptop has memory stick support, if has then use it to transfer you images. Otherwise you've to purchase a memory card reader with memory stick read support[should be available on any nearby electronic shop].
  • Then remove your memory stick from your camera and connect it with your laptop.
  • Open the memory card and copy your images.
Mar 15, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
How to transfer pictures from computer to camera memory card?
Below is how to transfer your photos incomputer to a memory stick in Windows XP operating system 1. Insert the memory stick into a compatiblememory stick reader. Plug the memory stick reader, with the memory stickinserted into it, into the computer's USB port. 2. After a moment, a screen thatsays "Removable Disk" will pop up and prompt you to take an action.Click on "Open folder to view files using Windows Explorer." Thiswill open the folders on the memory stick. Select and open the folder whereyour photos are stored. 3. With the memory stick folderand the photo folder open simultaneously, use the mouse to click-and-drag thephotos to the memory stick folder. 4. Close all folders and removethe memory stick reader from the USB port. 5. To ensure that your photos havebeen transferred, plug the memory stick back into the USB port. When the"Removable Disk" screen pops up, select "Open folder to viewfiles using Windows Explorer." Once you see the photos on the memory stickfolder, you can close the folder and remove the memory stick reader from theUSB port.
Jan 08, 2011 | Fuji FinePix J10 Digital Camera
How to download psp games into my pc
Hi there, I came across an article which explains how to transfer PSP Data to your PC.
CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
FORMAT YOUR MEMORY STICK
In order to be able to use your new memory stick on your PSP, you'll have to format it. When you format your memory stick, the formatting will create a set of new folders on your PSP: GAME, MUSIC, PHOTO, and SAVEDATA.
EXTRACT THE SAVED GAME
This process will greatly depend on which software you use to extract zip files. WinRAR for instance offers the "extract here" option, which will simply extract the contents of a zip file to it's current directory.
TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
VERIFY TRANSFER OF SAVE DATA
To verify the integrity of the SAVE GAME data you have just transferred, use the PSP's built-in Save Data Utility. Select it from the "Game" menu.
Jan 01, 2011 | Sony PSP (Piano Black)
Hi i want to transfer some pictures from my home computer to my laptop how do i do this
You can use a USB flash memory stick. Plug it into the computer where the photos are located and copy the photo to the USB memory stick. Then remove the USB memory stick and insert it into the laptop and copy the photos from the USB memory stick to the laptop.
Oct 26, 2010 | Computers & Internet
How to scan photos from a scanner on to a memory stick I want to transfer old photos on to a memory stick to use with my digital photo frame
First, make sure the scanner is connected to your PC via USB cable.
Hopefully the scanner software is already installed on your PC, your scanning should automatically show up on your PC screen.
From there, save to Memory Stick and you should be able to view it on your digital photo frame.
What scanner model and brand do you have by the way?
Jan 30, 2010 | Canon MX300 Office All-In-One Printer
Can I transfer photos and videos from a memory stick to a DVD and how? Thereafter I want to delete files from memory stick for future use.
I assume you have a dvd burner and software to accomplish this. But most burning software will allow you to put what ever data you like on a dvd, pictures, music, video, etc.
The software may ask you at some point, what kind of dvd you are trying to make, and there should be some option labelled something similar to "data".
Sep 11, 2009 | SanDisk 2GB Memory Stick PRO Duo Memory...
Have a new sony dsc-w120 cyber shot camera. first digital camera and have no clue. also have memory stick duo. can i transfer pictures directly from the camera to my mac computer using usb...
OK,
Camera has small inbuilt memory that can store few pictures. You can copy these photos in memory stick by inserting memory stick in camera, go to Menu >> Copy >> Yes.
Memory stick stores many photos depends on its size and let memory stick in camera, hook it with computer and transfer photos from memory card.
Thanks.
May 05, 2009 | Cameras
Transfering Photos:
u try to buy one original memory stick reader..
u insert ur memory stick inside that reader.....
and dont forget connect ur memory stick reader to ur computer...
then
u follow the ordinary procedure to transfer ur files...
if my solution is useful for u means try to vote me
Jun 19, 2008 | Cameras
Importing data from stick to computer - deleting data on stick
Yeah, all you have to do is delete all the pictures on the card. It's easiest to do on your computer, not the camera. Just put the memory stick back into your computer and find all the pictures and select and delete them. If you've already transfered them to your computer then don't worry about it. If you delete the photos off the stick, they will NOT be deleted from your computer so just go ahead and do it.
May 24, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Brother DCP 130C All-In-One InkJet Printer Logo
110 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
