Question about Rowenta Professional DE880 Iron
No Steam From Iron
The steam control moves freely from left to the center position where the maximum steam indicator (long line) is located. At this point it starts to have a small amount of resistance to movement as control is moved further to right. The reservoir is filled with water to the maximum fill mark. The temperature control is set to the steam temperature range setting. The iron will heat as normal but not produce steam. The reservoir level is not dropping
  • 24 Answers
I can tell you the stem rod for the steam control is choke or faulty. These prevent the water going onto the sole plate that why no steam.You've to send for servicing at your nearest repair shop or agent.
Rdgs
alan
Posted on Feb 29, 2008
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 | Irons
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Water leaking out of iron no steam I have a Hamilton Beach Steam Storm Model 14560 Lost manuel
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840091300.pdf
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
Jun 20, 2011 | Hamilton Beach Steam Storm 14560 Iron
Will not send steam to the iron. Cleaned boiler cleaned reservoir. Help!! i love this iron.
Assuming the iron is hot???, move the variable steam control from min to max several times to clear possible blockage. Sounds like the steam valve is clogged.
Jul 04, 2010 | Rowenta DG-980 Iron
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
No steam from iron , is steam generator iron 12978 russel hobbs.Iron heats up ok.
check the dial is in steam position or maybe you may have build up in the line for the steam
Dec 13, 2009 | Irons
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Rowenta Professional DE880 Iron Logo
383 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
