Question about Garden
Won't run cough back thru carb. good fire, fuel at carb, new fuel filter, new air filter, new spark plugs
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
Sheared flywheel key?Intake valve stuck?Put piston at TDC then see where flywheel magnet is in relation to coil,should be center to center.
Posted on Nov 18, 2009
89 Polaris Ranger500 6x6 side by sideis coughing,spitting and backfireing thew carb.whats the fix
I would start by pulling and cleaning the carb, air filter and spark plug. Usually the cause starts with dirty air filters that gets the carbs dirty which then cause the polaris to run rich and the plug will start to foul. The unburnt fuel ignites at the wrong time and back fires. A less likely problem would be out of timing.
Feb 13, 2017 | Polaris ATV
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
Craftsman silver won't start
ground the spark plug to the engine block it should spark. sounds like you need to check the valves and push rods
Jul 04, 2017 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere 17 horsepower Kawasaki engine won't run WOT when blades are engaded
swap the coil with the other side and see if that plug gets sooty instead of the one that has been
May 27, 2012 | Garden
Ryobi 705R weedeater won't run. I can get it to
Yes, it is possible. Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
This should get it running for ya.
Good Luck!
Jim
Jul 24, 2011 | Tools & Hardware - Others
My pressure washer doesnt seem to run properly. i have changed the fuel,air filter,spark plug and the oil. It will start but runs poorly.
Ok the first thing you need to check is if the spark is fireing. To do this you need to remove the plug plug it into the spark plug cap hold it on the cylinder head pull the engine over it will pull easy and see if you have a blueish spark jumping the gap on the plug . If you do its not an electrical prolbem . Then put the plug back and plug the ignition wire back and remove the air cleaner see if it will start then .witch the choke on . If it still won't start try pouring a small amount of fuel derictly into the carbuator if it runs for any time at all or even starts to fire then its a fuel issue eighter bad fuel or clogged filter or carbuator needs to be cleaned. You can even put a small amuont of fuel right into the spark plug hole then put the plug back in and it should start You need spark fuel and air for any engine to run if you have all three its automatic it will at least fire Good luckwith this
May 22, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
I have a 1991 honda cr 250 I cant get to start at fist gas ran right thru carb and out bottom i took carb apart and got the floats to stop sticking cleaned it out with carb cleaner put back together but...
try a new spark plug. if u fowl out a plug some time they will not fire under compression.2 strokes need. fuel,fire and air, very simple engines.it is possible crank seal are bad .that doesn't allow the engine to create vacuum in the crank case.thus fuel and air will not make it to combustion chamber.
Jul 11, 2010 | 2002 Honda CR 250 R
Hi,i`ve got a yamaha fz750 1988..and it won`t seem to run on all four cylinders..i took the air box off and while it was running put my hand over each carb one at once and found that on carb 4 it stopped...
Hi JIm,
If it stopped @ 4 tht means thts the only cylinder firing .
Remove the spark plugs,earth @ on the cylinder head, crank start and check for sparks...if its sparking tht means the coils etc. are ok.
As the spark plugs are out exam them to their conditions visit this site for more details :-
http://www.spark-plugs.co.uk/pages/technical/diagnosis.htm
From here you would know if its carburator or probably it may need a complete tune up....carburator cleaning, float level..adjustment, valve clearance.. new plugs (gap to specs.), check air filter, replace or fit 'inline' fuel filter thn balancing of the carbs.
Hope this helps!
Oct 29, 2009 | 1987 Yamaha FZ 750 MG (Europe-US)
Weed eater won't start already Tried new plug
Did you check to see if the plug fires? If it shows a spark, check the air filter. Did you prime the carb? Does the fuel mixture mive smoothly through the plunger? If all that is okay, go through the carb. You might take a SMALL amount of fuel mix and put it into the spark plug hole, try to fire it. If it fires, probably your problem is the carb or fuel delivery to the carb....Good luck...Lee
Aug 27, 2009 | Poulan Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
