Question about D-Link DFE-690TXD Network Adapter
Linux cannot detect my dfe-690txd
I am runnin linux 2.2.14-15 and linux canot find card.
how do i get linux to see and configure my card
  • 20 Answers
Please reinstall your card
on the web of linux
Posted on Jan 26, 2008
D-Link Express EtherNetwork DFE-690TXDm?
Did you find a solution for this ?
You haven't received any help because there was not enough information in your request for assistance.
Feb 05, 2012 | D-Link Express EtherNetwork DFE-690TXD...
What is this DLink Express Ethernetwork card for??
hi nadeemsultan
this works exactly as like a built in LAN adapter to your laptop. You may use this as a backup for your built in laptop LAN adapter. Altough this is more useful for some IT professionals who sometimes require a two LAN setup. I have also attached a useful guide that if found on the product catalogue itself.
WHAT THIS PRODUCT DOES
Connect to your wired home network by adding a D-Link 10/100 Fast Ethernet Notebook Adapter to your notebook computer. Once connected, you can access shared documents, music, and photos from other computers in your network. If your network has a high-speed Internet connection, you can also check e-mail, browse the web, and chat with friends and family online.
hope this helps. please let me know.
janc30
Feb 16, 2011 | D-Link Express EtherNetwork DFE-690TXD...
The 100m light flashes but the 10m don,t flash even though connected but speed very slow
The speed you are connected to your network at is 100mbs.
the 10m light shouldn't flash unless that's the speed of your network.
the slow speed is probably due to the bandwidth usage to the internet.
if anything else connects the internet on the network it will share the bandwidth. also depends on the broadband speed you are subscribed to.
Mar 16, 2010 | D-Link DFE-690TXD Network Adapter
Linux 5 is not detecting my broadband modem
The connecting to internet is very easy in linux .
There are many steps but i am saying simple one
Initially configure the adsl router with ppoe over ethernet and enable dhcp address option.
Next plug the ethernet cable from router to the inteface of lan card.
Boot the redhat machine.
In the system-->Administration-->network options check whether lan card is detected and active .
If the lan card is not active activate and save
In lan card select option assign assig ip automatically
check whether ip is assigned by using command ifconfig .
Mar 11, 2010 | Red Hat Enterprise Linux ES Basic Edition
I need internet on yy pc card
You need an ADSL Modem & a Broadband connection. You run a cable from the Ethernet connection to the Modem/Router, and that connects to the telephone line, and then onto the internet.
Mar 03, 2010 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
I'm trying to get a driver for a D-Link DFE-528TX PCI Adapter. I cannot network the PC as it is missing at the moment (so I can't use this PC to log onto the net). All I can find on the net are driver...
As you already know, the adpater has been discontinued, but D-Link has the drivers online for OS's thru XP. Follow this link, choose the tab on the right "Support Resources" and you will find the drivers. While this is for the 500TX, it will work for the 528TX.
http://www.dlink.com/products/?pid=DFE-500TX
Sep 18, 2009 | D-Link DFE 528TX - Network adapter - PCI -...
Network card not detecting in RHEL4 & 5
The solution proposed by user 'Solutions58' seems to be about windows box since he is talking about 'Device Manager'
RHEL4 or 5 detect compatible NIC cards during boot up process automatically. Sometimes NIC may be detected but may not work properly due to lack of proper driver (a.k.a Module - in Linux culture).
Do this -
1. First find out from HP's web site if NIC for your model has Linux support. You can also use Google to find appropriate driver for your NIC. If yes then you need to follow instructions that are provided in the INSATLL file that comes bundled with the driver.
2. Otherwise buy a $10 NIC card which has Linux support. Disable your onboard NIC through your computer's BIOS and boot it. Linux should detect your NIC right away.
3. Following command can help you in your quest
As root
# dmesg | grep eth (Will show your detected NIC)
# service network status (Will also show configured & active devices)
# ifconfig -a (Will also show your network devices and related info)
# system-config-network (will let you configure your NIC via GUI)
(This would be your best choice)
# system-config-newtowk-tui (Will give you a text base interface to configure your NIC)
Aug 05, 2009 | HP Computers & Internet
NIC Connection question, Manual in XP, Automatic in Linux
Its depend on your LAN Card Configuration, something it obtain or directly detect your internet connection but sometimes its not. That is why to make sure that you can connect you manually put IP Address on it. Uncheck the limited or no connectivity on the Lan Setting to make that when you are using Obtain IP Address then it shows and detect your Router or Hub with internet provider.
Jul 29, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
Ethernet controller
Is this an external PCMIA card that you want to install into your laptop, or are you opening up the laptop and modifying the motherboard?
If its a PCMIA card that you are looking for, then I would suggest the D-Link DFE-690TXD PCMIA Ethernet Adapter. I have one that I'm using with an old HP notebook that has a fried internal network card. You can buy it from newegg for about 32 bucks with shipping.
Here is a link to it: http://www.newegg.com/Product/Product.aspx?Item=N82E16833127111
Mar 29, 2008 | IBM ThinkPad T40 2373 Notebook
D-Link DFE-690TXD
No this is not a wireless card. It must be connected with a wire to a switch or a router. All DFE-xxx products from D-Link are wired network adapters only.
Jan 16, 2008 | D-Link DFE-690TXD Network Adapter
D-Link DFE-690TXD Network Adapter Logo
246 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
